PurpleHeart
Joseph Piotrowski
i'm intrigued by this woods color but understand it changes (like cherry). i'm not sure to what degree.
anyone make a project out of this? how did it look in a few years?
what finish did you use?
TIA.
PurpleHeart
Joseph Piotrowski
TIA.
Re: PurpleHeart
Michael Bush
I have a bunch of it. I bought 900 bf of it once upon a time when opportunity knocked. That was around 1991. Sold some, gave some away, used some. It will "brown out" pretty quickly in the sun, but the boards I have that are still in storage are still quite purple.
it becomes a beautiful brown
Re: PurpleHeart
Robin Corell in Atascadero
When freshly cut or sanded it is a dull pinkish color and develops a deep purple after a few days of exposure to oxygen. With out a finish it will eventually turn an unattractive brown and with extended exposure outdoors it will go silver. I have had the best luck in keeping it from going brown by using Generals HP Poly and I have had the poorest results using oil based finishes. I have a piece with purple heart legs finished with Nitrocellulose lacquer 10 years ago and it is starting to turn more of a red rather than a deep purple.
Re: PurpleHeart
There is purple heart and then there is purple heart. I've had some that was quite different from others.
Some I have is a real boring brown when cut then turns a wonderful purple when exposed to the light. Then after a few years it starts to turn brown again.
Then I have some other purple heart stock that when freshly cut is already a great purple color. Maybe a different cultivar or a
A good sealing finish does seem to help as does keeping the finished piece out of the sun, I'm guessing UV is a big culprit. I have some spindle turnings at least 8 years old that are still quite purple.
What is funny is a gentleman from South America that used to hang out here said purple heart was strictly a utility wood in his locale, used for things like floor joists and pallets.
Re: PurpleHeart
William Duffield
There are 23 species in the genus Peltogyne, all of them called Purpleheart. So, there is more than one way they express their purple color. The wood dealers don't usually tell you which species they are selling you. When it turns from purple to brown, you can sand or scrape off the surface color and restore it to its original color. Purpleheart is closely related to the rosewoods––they're both beans. It is strong and rot resistant, but also fairly brittle, and the splinters are very painful. If it is figured, it is about the most difficult wood to hand plane I have ever encountered. Miami-Dade used to use it for picnic table tops, in a very hot and wet climate. It is also used for pilings. I make spatulas from it. I still have the first one I made over 20 years ago. It gets heavy use cooking, and gets washed regularly in the dish washer.
Re: PurpleHeart
Michael Bush
The batch of it I bought in the early 90s had been used to build pallets and boxes to import Brazilian pottery. Some of it was beautifully figured. I used the figured pieces to make guitar back and side sets and sold them to luthiers. That's a considerable step up, from pallets to classical guitars!
use a heatgun
Bruce Mack
A heatgun will greatly deepen the purple color. I can't tell you how long the color remains intense.
Re: PurpleHeart
David Yoho
I was the recipient of some of Michael's purpleheart years ago. I believe there is still some stored away in my stash of lumber on the top rack, which I haven't looked through in years. I did make a table top with some of it where it was glued up along with strips of mahogany. Twenty-some years later the purpleheart is a deep burgundy color. The finish was Danish oil and wax.
Re: PurpleHeart
Bill Turpin in WNC mountains
Turned a purpleheart pen for a wounded vet that never got his PH medal. I dyed it with purple TransTint. It is still purple, another method to keep it from turning brown.
article on color change
If anyone hasn't seen it, the Wood Database has an article on wood color. It mentions using dye:
http://www.wood-database.com/wood-articles/preventing-color-changes-in-exotic-woods/
Re: PurpleHeart
Michael Bush
Burgundy is a good word for it, David. No doubt the color variations go to the variety of species. All my batch of it is and always has been red-purple. Some I have seen is more blue-purple.
