Belt slipping on Performax Problem
I bought a new drive belt for my Perfomax from WoodCraft. Its like a big sanding belt with a cloth backing. Could not get it to track so I bought another one from Kingspor. That one tracks fine, but now it slips. Its got some sort of film backing and seems slick on the back side. It worked fine at first, but now that it has been on the machine for a few months its slipping and the work pauses and creates a line/dip across the panel.
Is the answer to tighten the belt tighter? Did it stretch? How about some anti-slip stuff? Did the rubber roller dry out?
Re: Belt slipping on Performax Problem
Don Orr
I have the same unit but I don't use it much-got it 2nd hand. It never slips but it is pretty tight. I'd try tightening 1st before any other measures. I love my machine-it has done some excellent work for me over the years, and I've used it hard at times.
You sure that film wasn't supposed to be removed?
Re: You sure that film wasn't supposed to be remov
I am not describing it well. Its made out of Mylar or polyester. Some sort of plastic film rather than cloth. 99% sure there was nothing to remove, but I have been wrong before. I called Klingspor and left a message, but they have not returned my call. I don't know how much to tighten the belt or how much is too much. Its got a bolt on each side that pushes a roller out to tighten it and I increased each one a half a turn, but I am just not sure how far to go.
It does surprise me the rollers are so small.
I still have the cloth belt from Wood Craft. I thought it was tracking and ran a long piece through. Before I realized what was happening it ran to on side and scrubbed against something, sort of curling the edge. Ticked me off, but I did not feel I could return it. I may have to try it again.
Clean the rubber drive rollers
Dick Coers
Have you tried cleaning the rubber drive rollers? A little denatured alcohol on a rag will remove all the dust and get the rubber back to being a little tacky. Also clean off the mylar film. Do you have good dust collection hooked up to the machine?
After my years as.....
Brian Roberts
a typewriter/ copier tech I can tell you that alcohol is not the best for rubber rollers...in fact it will dry them further.
Use an actual "rubber rejuvenator" or just a a scrub pad and water.
Understand, though, that replacement is the best way to "rejuvenate" old, dry, hard rubber rollers.
Thanks, I will clean them....
I doubt I can buy a replacement roller. Performax was sold. I wonder if the new company makes exact replacement parts?
As a last resort, you might try this
Keith Newton
Some years ago, the rubber fell apart on my old edge sander drive wheel. I needed it badly for a project faster than I could send it off for a re-build, so wandered over into "Necessity is the mother of invention" territory.
What I did, was to hold the coarsest grit paper against it while it coasted after hitting start/stop. After roughing and cleaning, I sprayed the roller with hi-strength contact while it was slowly spinning. I got a nice even build up, then let it dry. I'm sure it has been at least 5 years, but maybe 10, and it still works fine.
I spoke to Klingspor's service guy.....
They were nice enough to call me back. Their only suggestion was to clean the drive roller and tighten the belt. He did tell me that he is sure I can by a replacement roller from Jet if it comes to that. (Anybody KNOW if Jet parts are really interchangeable with Performax parts?)
You have more phone calls to make.
Gary Smyth
You ought to call him back and ask what (which?) Jet roller and why. Failing that call Jet. Seems to me the source is a more reliable answer than what may be offered here. Let us know.
Re: I spoke to Klingspor's service guy.....
jessecloud
Jet bought out Performax several years ago and immediately started replacing steel parts with plastic. Still, it would be worth a phone call. Be sure to have make and model and manufacture date if available.
I doubt there is anything special about the roller, other than its size.
He told me to have the Model number....
and Serial number in hand. I bought the machine used, but I have most of the documentation.
He did tell me that his personal machine did the same thing and he tightened the rollers until he could not stop the belt with his hands. Somewhat scientific but better than nothing. He is sending me a picture of his hands......Not.
Ken Krawford
Those parts are definitely interchangeable. I was having problems with belt alignment on my Performax 16-32 and Jet support initially suggested the rollers were the problem. I purchased new ones and they fit perfectly however they weren't the problem.
