Question on color/aging cherry wood
I have been working with cherry. I know you can put it in sunlight and it will darken. I noticed that if it sits around indoors and not in direct sunlight it will darken. I was sanding and noticed the darker color sands off and then starts darkening again in very short order. An hour later when I go to the next grit more color sands off again.
I assume this is some sort of oxidation. ???? Is this the same thing the sun causes? Or is it two different things. And does the darkening process happen under the lacquer finish?
Re: Question on color/aging cherry wood
I assume this is some sort of oxidation..... promoted by light
Is this the same thing the sun causes? any light
And does the darkening process happen under the lacquer finish? yes
Finish is permeable to oxygen and light.
To add a couple points to Bill's answer...
John in NM
It will happen fastest with unfinished wood, and the rate for finished wood should depend on the kind of finish - BLO vs lacquer are probable the two extremes (I have not made a study of it however).
You can also get an immediate color change by treating it with a dilute base. Lye, ammonia, and water out of my plaster barrel are all ones I've tried.
Sunlight will eventually bleach the wood, so beware. That is more of a problem for us in the southwest than in Virginia I would guess.
John McGaw
I've noticed that some cherry darkens faster and darker than others regardless of finish. The stuff on my big bathroom vanity is really dark and it has a film finish on it; it never gets much light in that room being on the north side of the house with only a small window. The darkness is always pretty much skin deep in my experience.
I went to a mill way back when and picked through a stack of what was supposed to be wide boards of 5/4" rough walnut -- really dark stuff. When I got it home and started to use it I found that over half of it was cherry that had gone almost black but that color was really only surface thick and milling it made it look pretty normal. Some of that cherry went in to my desk and after 12 years it is still pretty normal cherry color.
jerry roberts
I too am concerned about the color change with cherry. I'm in the process of building a tv credensa that primarily has a coupel shelves that along with other stuff , will hold a large amplifier and also a cd player.Should I be concerned after a few months will the cherry darken around the equipment and leave a light area under it? If so , how do I prevent it?
