THE WOODRAT IS BACK!
Another mistake I made so you don't have to...
I was spraying the bed I made with Sherwin Williams lacquer I bought based on a recommendation I got here. (Thank you to those of you who suggested it, it looks like good stuff)
I sprayed the back of the foot board and let it dry about an hour, nice and dry to the touch. I had it rest flat horizontally to help me avoid runs drips and errors. Turned it over to spray the show side. Left it there over night. We all know something mystical happens in the night. My stick I had it resting on had packing tape on them for reasons I don't actually remember. Turns out packing tape with fuse into lacquer that is not fully cured, but dry to the touch. Had to scrape it and the finish off.
Nails driven into blocks are better for this application.
Re: Another mistake I made so you don't have to...
Joseph Mulherin
Barry, my suggestion....make some newels to plug into the holes you leave after you do this:
Hang the parts from the rafters, spray both sides, let dry for a couple days, the insert the newels into the holes glued and the job is finished nicely.....no mess, easy cleanup.
Joseph, What is a newel?
I thought it was a "newel" post. What is another kind of newel?
I do hang up many things to spray them. This time I wanted to lay them down to avoid runs.
I also need some kind of curtains to make a temporary spray booth. You should have seen the over spray that came out of my home made air cleaner. It did a fabulous job.
Re: Joseph, What is a newel?
Joseph Mulherin
I meant a plug designed in the shape of the topping on the newel post.
Mike Jurnigan in Zuni
Evening Barry,
This is what I had in the other shop back in the BD days (Before the Divorce). This was told to me by a guy that I worked with that did a lot of automotive painting in his home body shop. I had a frame made from light weight metal conduit that was suspended from the ceiling. I used some parachute cord to suspend it from the ceiling as all my structural members were steel. From that I suspended some 6 mil poly. The poly was attached to the frame by standard cafe curtain hangers (supposedly that is critical). The poly was one continuous piece all the way around and had an opening on the side that you slid together or apart to open or close. The poly ended approximately 6-12 inches above the floor. At the opening, you attach the leads of a battery charger, one to each side of the opening and turned the charger on when ready to spray. The charged poly acts as a magnet and draws the over spray to it. It sounds crazy, but it works. I had no over spray in the shop. Prior to using this spray booth I would have cloud of over spray so thick you could hardly see across the shop. I know this is something that OSHA would not probably approve, but it is what I used in my old shop and will use in my new shop.
Hope this gives you an idea.
Mike in Zuni, VA
by sliding the curtainvbm
Joseph Mulherin
Interesting
Thanks Mike, A few details please?
I take it this has to be an older battery charger that does not have the electronics that sense the presence of a battery and won't operate without one. Just good old fashioned On and Off.
The charger just hooks to the poly? Not the metal frame? (struggling with the idea that poly is non conducting, but the metal frame might burn the house down.)
Are the cafe hangers metal or plastic?
Why 6" off the floor? Can it touch the floor? Grounding or something?
Can the curtain drape over tools etc? My shop is so small I have to go out side to change my mind. Can the curtain be in pieces or must it be continuous?
As you can see, I am fascinated by your suggestion. In my previous shop I had a homemade spray room, but that was 35 years ago. I have an old battery charger. One of the few things that survived the divorce. So I am ready to give it a chance.
Thanks Joseph. My problem here was that like a lot of us I treated finishing as an afterthought. I have heard that finishing any piece is half the work. In this case I tried to cheat and do a easy quick job. I need to set up a better way to spray. I don't have room. It's a quandry. Tiny shop blues. I do know what the plugs are you are speaking of and even though they would not have worked well in this design, I could have easily made ways to do this better. Just got the bit in my teeth and the end was in sight.
One more detail....
I had used this stick with the tape on it several times, turning this piece over, back and forth. It worked well , not marking the dry to the touch lacquer and lone as I only left it in place for an hour or so. Apparently leaving it for an extended period, overnight gave the residual solvents time to work their mischief.
(Message Deleted by Poster)
Gary Smyth
With all the sales you go to you might find this as an an alternative. Adapted a "picnic" tent approx. 10 x 10 by 6' high at highest point. Got it at a garage sale for about $30 as I recall. Have to put a tarp on the floor, to get what spray falls but it's a nice spray booth in still air and in season. I used in garage and out. Works best with lots of light. The screen eventually gets clogged and can be a pain to set up and break down but I don't use it that much. Can get hot in summer. Does keep out blowing debris and most bugs. Works in a pinch. Wear mask and take breaks on large jobs.
Chuck Jurvelin
Barry, what I have used for years are 4" squares of scrap plywood with a 3"- 3/8" dowel that has been sharpened to a point on one end and inserted vertically in a hole in the center of the plywood square. Finish the back side of the project with at least two coats of lacquer, then turn it over and balance it on the points of the dowels and finish the front face. I use as many of these as is necessary to balance the object you are finishing. Also, this allows air to get to the previously finished backside. Also, you will find that spraying a relatively dry first coat and letting it flash until it is somewhat dry, will allow you to spray subsequent coats considerably heavier without the fear of runs or sags.
Bruce, a MN Galoot
I use shop made wooden pyramids, similar to these (image copied from Highland's site)
Re: Thanks Mike, A few details please?
Mike in Zuni
Barry,
In response to your questions:
I take it this has to be an older battery charger that does not have the electronics that sense the presence of a battery and won't operate without one. Just good old fashioned On and Off. That is correct.
The charger just hooks to the poly? Not the metal frame? Again, correct.
Are the cafe hangers metal or plastic? They are metal. The ones that I used were brass plated. You slide them over the conduit. They are the type that you pinch and slip the poly up into them. You could use metal shower curtain hooks but you would have to punch holes for them. Also the cafe curtain hooks makes it convenient to remove the poly. I left my frame up after the first time. When installed my whole unit was insulated from the structure.
Why 6" off the floor? Can it touch the floor? Grounding or something? 6" was arbitrary number. As long as it does not touch the floor.
Can the curtain drape over tools etc? My shop is so small I have to go out side to change my mind. Can the curtain be in pieces or must it be continuous? I have no experience with it draping over other tools adjacent to the curtain. The curtain needs to be continuous.
My knowledge of how this thing works is as follows: The poly has a static charge which is the opposite of what is generated by your spray gun while spraying. The charge on the poly attracts the oppositely charged over spray. The charger someway helps maintain the charge. Don't ask me how, because my knowledge of electricity is just enough to be dangerous.
When in use the poly developed a heavy coating of over spray and in time the poly gained weight and became stiffer. What did not adhere to the poly fell to the floor inside the curtain. Prior to using this when I sprayed in my closed shop I could barely see across it and everything had that powdery dusty feel to it. After installing it, immediately after spraying I had no cloud in the shop and no over spray dust on the tools and equipment. It did not do anything for the lacquer smell and I still had a headache.
Hope this helps,
Mike
I'm skeptical, and alarmed
A measly 12 volts is not going to charge an insulator like poly(ethylene). I would like to see the experiment repeated without the charger. I predict it is not doing anything.
The chance of a spark from this arrangement is alarming. The result would be an explosion either of solvent and/or the finish dust.
***A REMINDER***
Just remember that the advice you get here on this forum is that of our posters, not of WoodCentral, and that WoodCentral will not be responsible for the veracity, safety or advisability of anything you read here, or liable for any negative consequences of actions taken by you as a result. We often discuss controversial or potentially hazardous techniques here to get a look at all sides of an issue. This is the great value of a forum. How you act on this information is strictly your responsibility.
WoodCentral.com
Re: I'm skeptical, and alarmed
My brother works for an automobile maker in the repair paint department. He said electrostatic painting was widely used. However, it requires a high voltage (and I suspect low current), not something you could get from a battery charger.
Amen and got it!
Re: ***A REMINDER***
Thanks Ellis. Always good to have a sober reminder. I am struggling with my spray gun. The one I am using now was a gift from a friend and it sure seems to put a ton of over spray in the air. I have ordered the one Bill recommended. We will see.
