ADVERTISE HERE - FREE TRIAL
How To Attach Shelf
How To Attach Shelf
How To Attach Shelf
Stuart Johnson
I'm getting ready to make a plant stand from a photo my wife supplied. No problem on dimensions but I don't know how to attach the shelf. Any suggestions? I have biscuit joiner, beadlock and a shop full of other tools but no budget for new stuff.
Re: How To Attach Shelf
John McGaw
Is the shelf to be adjustable? If not, and given the limited amount of 'meat' you have to attach to in the vertical portions I'd consider simple dowels -- four of them at the corners of the shelf. Or, if you have the equipment and won't be staring at the stand from the bottom some pocket screws would do the job neatly.
Hi Stuart,
There are a couple missing pieces to this puzzle. First, is the shelf necessary to the structure of the plant stand, or is it just a convenience that you're adding in? Also, are those vertical slats the same thickness as the legs, or are they set in from the plane of the legs. If they're set in, I'd suggest making a little ledger to go between the legs, screwed to the slats, and then notch the ends of the shelf so it extends into that inset space. You can also notch the legs to receive the corners of the shelf, but make sure you take expansion into account. If the shelf is solid wood, it will move with seasonal RH changes, while the leg assemblies may not, depending on the design.
Of course, you can get into some fancy joinery if you like.
How about assembling the sides and cutting a stopped dado across the assemblies and slipping the shelf into it as you make the final assembly. A little glue and or a few pins. You could make the shelf grain run front to rear and let the flexibility of the sides absorb the seasonal expansion and contraction.
TomD
So here is an option. One thing I do even for "fixed shelves is use adjustable pins. I will either put in only one set of holes, or I will put in a few. Particularly if you do not have a whole series of adjustable shelves, you do not need to put in holes all over the cabinet interior, normally one does not need to adjust a single shelf all that much, what drives the multiple holes is that with many shelves minor adjustments to one shelf can cascade through the unit requiring significant adjustments. So say you only have one set of holes. In shear, even the smallest pins are bomber. The problem is whether the sidewall are stiff enough for the anticipated shelving loads, or whether they will cause the stringers in your design to bow. So what you do is get some M5 (5mm cap screws, very cheap, you can get them most places and also just get them sent from ebay at really nominal cost) hardware. Drill your holes at 4 mm. Tap the holes ( or do some tests to see what hole will work without taping, a small notch in one of the screws will convert it into a tap), insert the screwa. These now become t-heads that can engage in a lip or simply designed not and take on any loads parallel to the ground that would cause bowing.
If you think your structure is stiff enough by itself, just use these:
http://www.leevalley.com/en/hardware/page.aspx?p=52895&cat=3,43648,43649,52895
Do not use the sleeves, they largely look tacky and draw attention to the holes. 5mm holes by themselves are bomber in hardwoods, and plywoods, and can barely be seen. The only thing about them is they are really stiff when one first tries to insert a support , particularly when you initially finish over them, Just grab a spare support in vise grips and use it to clear the hole, I just clear them as I use them. Commercially I might invest in a 5mm + 1thou chucking reamer. or a 5mm reamer.
Thanks for the advise
Stuart Johnson
Based on the answers I have decided to change the design a bit. The shelf will be in shallow dados with biscuits glued into the uprights but not the shelf. It will be able to move and I don't have any worries about the structure as it won't hold much weight.
Thanks for the ideas.
