What brand/type of spray gun would you buy?
I have been using a spray gun with a quart cup below the nozzle (syphon feed?) for many years and its finally time for a new one. I am spray lacquer mostly and on furniture. I have an air compressor that will keep up with that gun nicely. What brand and type would you use for this application. (tip size and other details?)
Re: What brand/type of spray gun would you buy?
Stuart Johnson
I can't say what is a good buy but I bought the Rockler HVLP and do not like it. It sprays well but the type of connection are about like a hose plugged into a cheap vacuum sweeper and keep pulling out.
No charge ;)
Re: What brand/type of spray gun would you buy? *LINK*
Call Jeff Jewitt at Homestead. He sells guns in various price ranges as well as finish products. Bought my pressure-pot Walcom HVLP conversion rig from him.
One note: If you're spraying solvent finishes, stay away from the HVLP turbine rigs as they heat the air and will flash the solvent giving you serious orange peel without using lots of retarder.
Note Two: You get what you pay for in this area. Apollo makes a great gun line (the "Atomizer" ) that can be set up with either a top or bottom cup in either siphon of pressure feed with a further choice of compressor or turbine. It ain't cheap however.
Homestead
Re: I second the Jewett recommendation
Hank Knight
I have called and spoken to Jeff Jewett at Homestead several times with questions. He is always accessable, friendly, helpful and extremely knowledgeable. Give him a call. You won't be disappointed. Additionally, he frequently has great deals on spray equipment, either over-stocked, discontinued or scratch-and-dent items. I bought a very nice HVLP conversion gun from him on his recommendation several years ago for about half the original price, and I've been very happy with it.
Hank
Re: what is wrong with what you got
I had a Sears gun for years and something failed on it, for the life of me I can't remember, but the part was irreplaceable. A friend gave a similar gun and I am struggling with it. Its old and decrepit and so am I. Right now its spraying a narrow pattern, making it hard to get nice even coverage. And its spitting. Sort spray, spit, spray, spit.
There is a knob on the side of the body. A little black plastic knob that appears to be on some kind of air valve. I tried to turn and it came off in my hand. I quickly stuck it back on like a kid trying to put the cookie back in the jar.
I was thinking that rather than put much effort into this gun, I would get a new one to last me the rest of my life. Right now, my goal is to live longer than my dog.
Joseph Mulherin
Barry, You are always trying to do things on the "cheapest" side, no disrespect in that, so I am suggesting you go to Harbor Freight and see what the have on the high side of their paint guns.
I have one but have not tried it out as yet.
Central Pneumatic, Item no. 67181, air pressure 50-70 PSI; paint output 7-10 fl.oz/minute;
nozzle size 1.5mm; cup capacity: 20 fl oz.; air inlet 1/4"-18NPS
Cost I think was about $35.00. Should do what you need.
go to Ebay and
get any Delvelbiss gun that says JGA then buy a #30 cap if it needs it. If it doesn't come with a cup that is good. Buy the 3M PPS disposables. I like the medium sized cups, 200 mL I think, in any case one size up from the tiny ones (100 mL).
Joseph, I take not offence. I have been known to be cheap. Sometimes I struggle wondering if there is a real difference between a moderately priced tool and a very expensive one. As you know I recently acquired some Festools. (Track saw, router and sander.) Especially sweet for me because I got them at an auction...Cheap. But they are slowly dragging me over to the Green Kool-aid. They truly are well built and great functionality.
I went through a spell recently where I was so strapped I could not afford to eat off the Dollar Menu for a year or two. Doing better now. Maybe I don't have to be so cheap and can afford to buy some nicer tools and upgrade my game and enjoy it more.
The point to this question was to not spend on the wrong thing. I want to spend the money and get a good gun. As opposed to spending the money on a best guess and getting crap. I'm going to call Jeff Juett and Check out the gun Bill recommended. (I buy Harbor Freight when I want a throw away tool)
Re: go to Ebay and
Thanks Bill, I will be checking those out. They range from $9.99 to close to $300. Any further advice? I remember Binks and Devilbis from back in the day. Its says something if they are still around.
Re: go to Ebay and
You should be able to get one in good condition for about $50-75.
I just checked and there are loads of them. Nobody wants them because they have gone to HVLP to meet EPA regs. Not a problem for me.
A #30 cap is good for lacquer. I have used a #43 with good success also.
Thanks, and a question
Are parts still available? If the gun I buy comes with the wrong cap, how hard is it to get the right one?
And the cups from Sherwin Williams fit as they should? Do they come with caps you could use off the gun?
Re: Thanks, and a question
ken combs
IMO, you shouldn't buy any gun that needs parts as parts for a good gun will be expensive and could quickly add up to the cost of a new gun.
Also, you'll find gravity feed guns to use a lot less solvent to clean, are much faster to cleanup and you can use all the material from the cup. that's important if you are using high end (expensive) finishes..
I no longer have any siphon feed or 'normal' guns, all are HVLP. With the price of quality finish materials, the cost of a good hvlp, gravity feed can be a savings in the long run, if you spray a lot.
At the upper end, a Devilbiss GTI is an excellent gun and can spray, primers, stains, clearcoats, lacquers, enamels etc with the correct air cap and tip.. It is available as a kit will everything you need.
I actually use my Harbor Freight purple guns more than any other. The good one (the GTI) is reserved for final coats of poly and auto clear.
Re: Or
TomD
I use an authentic Badger detail gun for a lot of stuff, in a non-pro spray setting it puts out a lot of material while still being good enough for stuff like instruments.
I used to have a neighbour who was a pro on guns, he sold and serviced them. He sold gear to the guy who sprayed the CN tower. When he retired he outfitted his van and installed a generator rig, and this little 2K unit that was the ultimate compressor such as was sold for the CN tower job. He then did a job of sealing driveways with full grade tar out of this machine. It was awesome. Anyway, when he wanted to do a detail job, he just bought a 16 buck anodized aluminum HVLP job from the equivalent up here of HF, and tossed it if the media was too nasty to clean out. He said they were great for what they were, not worth fixing but would last as long as the replacement kits for guns like the badger.
Are parts still available?.....probably yes. Auto paint stores usually have them. If the gun I buy comes with the wrong cap, how hard is it to get the right one?...probably trivial. Often can be found on Ebay.
I checked and there were plenty of guns for $50-75 that look good to go.
And the cups from Sherwin Williams fit as they should? Do they come with caps you could use off the gun? ...Don't understand these questions.
PS on Cups
I find a quart cup uselessly too big for furniture. Pint cups are available, but the utility of the 3M pps system makes spraying so much easier. (another company I don't remember makes a similar system but I forgot the company. I have an extra conversion piece for Develbiss to this system. They enable the gun to used upside down, cleaning only uses a few mL of solvent, 100% of what is in the cup sprays, they are light weight and small which makes maneuvering the gun among furniture parts convenient, etc.
Dave Nichols
Eastwood has a good selection of spray guns, here's a link http://www.eastwood.com/paints/paint-equipment/paint-guns/devilbiss.html
Thanks again...I bought one....
JGA with a No 30 cap and a small cup. Be here in about a week. Now we will see what I can do with it. Thanks for the help.
SATA RPS system
GolfSteve in Calgary
The "SATA RPS System" uses disposable/sealable PVC cups. Extremely handy.
I'm currently spraying house trim. Two coats of shellac (then a quick sand), two coats of gloss waterborne varnish (quick sand), and two coats of satin waterborne varnish.
I can switch between finishes in seconds and unused finish remains in the cup until I need it. In addition to the cups of shellac, gloss WB, and satin WB, I have a cup filled with water and another cup filled with lacquer thinner to use when cleaning up after spraying.
As far as a gun recommendation - I've only used one and I'm happy with it: a SATA Minijet IV with a 1.2 mm nozzle and 0.6 litre RPS cups. I also have a 0.8 nozzle, but never use it, and a pressure pot, but also never use it. If I don't screw up, the satin waterborne finish is flawless right off the gun.
These doors were sprayed flat in the shop. The trim was sprayed in place.
step one
Lacquer solvent is excellent solvent for paint. If there is a speck of paint anywhere in the gun it will dissolve and redeposit on you cherry table top (or whatever). >( Get a brush and some lacquer solvent and clean every internal surface. The guns are easy to disassemble. Put a tiny bit of oil on outside surface of the needle seal.
