Furniture repair query
Barry W. Larson
Gentlemen:
My wife has a rocking chair about 35 years old (predates our marriage) that she received from her family as a gift. The back spindles are loose and the cresting rail (I think that's the right name) has become detached from the spindles. I have no idea what glue was used to assemble this chair nor do I know where it was made. It is not an expensive piece of furniture but it does have sentimental value. My question is would liquid hide glue be appropriate to repair this chair? I could likely use regular yellow or white glue or even chair doctor from Lee Valley, but a little voice is telling me these may not be the best choices especially if there are problems later. Perhaps Mr. Tindall has some words of wisdom here as he seems to have a wealth of information on glues and their appropriate uses. I have ready access to Franklin Liquid Hide glue from a number of sources. Any and all advice is appreciated. Thanks in advance.
Barry W. Larson
Calgary, Alberta, Canada eh!
Re: Furniture repair query
Hide glue would be appropriate. It gives you more open time than many other glues. It is also easy to clean up.
Old Brown Glue is the name of a reasonable brand of liquid hide glue.
I often use it to glue the crests of chairs to spindles.
The important thing is to have a plan and an idea about what you are doing.
I usually get a yogurt or paper cup and a small brush and use that to apply the glue.
Marty
I agree with JL. Take plenty of pictures,as to the re-assembly.I am on my 7th rebuild of a rocker. Don't know why,but I keep looking for the old ones to rebuild. I use Titebond,has not failed my yet. Use a Heat Gun for the dis-assembly ,GO VERY SLOW. I have found the 6 out of the 7 have been assembled with Hide Glue
Jack Guzman from Maine
I repair alot of chairs. I always use liquid hide glue. The main reason I use it is because of the fact that it can be reversed with heat. Chairs take much abuse and it is common for joints to come apart. One thing I hate to see is a chair that was repaired prior with yellow glue. In removing the old glue the joint is made too loose so I need to get creative with shavings or some other way to tighten the joint. If a hide glue joint fails I just clean with hot water or steam and some abrasive like a rag or brush and then reglue the joint. My glue of choice is Patricks old brown glue.--- Jack
Re: Furniture repair query *LINK*
Hank Knight
Hi, Barry,
Hide glue is your best choice for your repair, especially if the chair was originally assembld with hide glue. New hide glue will stick to old hide glue that has been softened with hot water, so repairing an old hide glue joint with new hide glue is a snap and makes for a strong joint. Most glues, including hide glue, don't adhere well to modern glues like yellow glue(PVA) and white glue that have already cured. If your chair was assembled with one of these, you will need to remove the old glue with a scraper and sandpaper to get a good bond. If the original glue softens readily and becomes tacky in hot water, it is probably hide glue.
I repaired a kitchen chair with two broken rungs this weekend with hide glue. The chair had been glued originally with hide glue. I used dry granulated glue dissolved in hot water for the repair because that is what I have on hand. There are very good liquid hide glues on the market. Old Brown Glue is one. Franklin, the Titebond people that you mentioned, make a good one. Bill Tindall has recommended Franklin liquid hide glue recently in a post on this board.
You can disassemble a hide glue joint easily with hot water. Some people recommend steam and/or drilling small holes into the joint so the hot water can penetrate. I didn't find either of those methods necessary. I just kept flooding the joint with hot tap water and wiggling the rung until the glue gave up and the rung came out - maybe two minutes max. I used one of these accordion injectors to apply the hot water, but you can use a hypodermic syringe or anything else that will allow you to direct a small stream if hot water onto the joint.
[URL=http://s50.photobucket.com/user/hankknight/media/IMG_1738_zps8hswtmmu.jpg.html][/URL]
See link below
Once the joint was apart, I removed the excess caked on old glue, applied new hot hide glue, reassembled the joint and set the chair aside overnight. It was good as new the next morning. I didn't find it necessary to clamp the joint, but you may. Clamping chairs with ordinary clamps is often awkward. Sometimes it's easier to pull the joint together with strong elastic bands or rope.
Good luck with your repair. It's not as complicated as it sounds.
Hank
Lee Valley glue applicators
Barry W. Larson
Thank you gentlemen your advice is greatly appreciated. Sounds like my idea to use hide glue is the correct one or at least the one that will allow for future repair should it become necessary.
Cheers,
Barry W. Larson
William Duffield
My favorite syringe for injecting glue or hot water is the Monoject 412. On Hank's Lee Valley link, it is item 25K07.05. You can get them in bulk (50 pcs.) elsewhere for a lot less than Lee-Velley's single unit price. If someone were interested in organizing a group buy for their local organization, this is the way to go.
jessecloud
The Monoject 412 is my favorite, too. Great for string inlay as well. The 412 has a curved tip, but if that isn't what you are looking for, there are many other Monoject (and other brand) models with varying shapes and capacities.
If you need it in a hurry and you know a veterinarian, drop by and talk him out of an "irrigation syringe."
A vet supplies place might also be cheaper than Amazon.
If you remember to wash it out promptly after use, it will last for a very long time!
William Duffield
I get needles from my vet. My Sister-in-Law gave me a carton of syringes without tips. She loads them with Jello shooters. I use them for epoxy. I clean out the needles with acetone so I can reuse them, but it ruins the syringes, so I'm glad they're cheap and disposable.
I like Steve Latta's trick for glue and stringing: He sticks the tip of the Monoject in the tip of the glue bottle, so it is readily available for the next strip of stringing, the glue doesn't harden in the tip, and he has plenty more glue to refill the syringe.
