Ebonizing Mahogany
Ebonizing Mahogany
Ebonizing Mahogany
Mark
I am experimenting with a Gibson Les Paul style Guitar Kit and wondered if anyone knows a good recipe to ebonize mahogany?
I can look for some Ebony veneer and apply it to the headstock but thought maybe there is a staining tip ?
Re: Ebonizing Mahogany
Black TransTint dye in alcohol followed by black shoe dye has worked pretty well for me.
don stephan
Mark
Some experimenting might be helpful. When I was asked to make cherry nearly black, two applications of Transfast black had to be followed by one or two wipe on gel stains from General Finishes, and the cherry color still ghosted through in places. It was an interesting look, but I'm not thrilled with adding any color to heart cherry.
Gary Smyth
I like Solar-Lux jet black. Takes at least three applications, but to my eye fewer tones of gray or blue. Test on open pore wood for satisfactory saturation. Also, India ink might be an alternative.
Not sure exactly what you are doing, but I have "blackened" several things by using flat black spray lacquer and then clear coating it with compatible gloss lacquer. As with all of these ideas, test first on scrap. I have done pieces and left the coarse grain visible, but no color of the wood. I have filled the wood and had a very slick shiny surface.
Tony - Memphis
I have used water based dye (Lockwood rfom Lee Valley) on poplar. It works very well. I keep a jar of it mixed up and use it on all sorts of projects where I want a touch of "ebony."
Tony
Re: Fiebing's leather dye +1
Robin Corell in Atascadero
looks good with a coat or two of tung oil on top of the dye.
