only a guide
Gary Smyth
From the web. "... if your current bed has no wooden slats, you can calculate the number you will need and the width of them easily. First, take the measurement of the length of the bed.
Most beds are around 80-inches long, and most slats are 2-by-1 inches. Therefore, in this example, you would divide 80 inches by 2 inches, which equals 40 inches. That means that there is enough space for 40 slats. However, you will need one slat’s worth of space between each slat, so you should divide this number in half. Therefore, you would need approximately 20 slats."
Personally I don't think you need that many, but it's a reply.
I have a antique cannonball rope bed that I use for guests. Modern mattress sizes are now a different makeup. Some time ago I had to remove the rope and in order to keep the frame I used 1/2 x 1/2 square steel tubing nested in a dado in a screwed on cleat on the inside of the original frame. I used ten lengths of the tubing and set a 1/2" fitted plywood sheet on top of them so that the top of the ply sits slightly lower than the top of the original frame. The box spring sits on the ply. Haven't given it a thought since then. No complaints, no crashes. Works for me.
Also, I looked up "bed slat kits". Amazon sells them. They don't say how many, but if you provide the size of the bed they provide some information. For a twin bed this is their information
Item Weight
20 pounds
Product Dimensions
75 x 4 x 39 inches
Item model number
128017-5010
Assembled Height
39 inches
Assembled Width
4 inches
Weight
20 Pounds
