I have a Delta 6" long bed jointer I have owned sine buying it new in 1971.
When I turn it off it grumbles at me as it slows down. I'm thinking new bearing would be a good idea. What About changing the cutter head at the same time? One of the spiral ones? Where does one shop for one? Or NOT?
Take off the belt and run the motor. Make sure it's not the belt or motor. Those sheet metal cabinets make a nice base drum. Cutter head style is personal preference, can't tell you what to buy. Also depends if you machine a lot of exotics, and how much you face joint.
Check the pulleys also. My DJ20 was making a racket while powering down and the pulley on the cutter head was loose. Start your search for the spiral cutter head online or NOT.
Definitely check the belt/motor, a belt could easily cause the noise you describe.
I put a Byrd head in my old PM100. Bought it right from Byrd with the bearings already installed (the old versions of that planer, like mine, used a weird and hard to find bearing - Byrd already had figured out which modern one to use instead).
If you mostly edge joint, I doubt the head will make a difference. For face jointing it could be handy.
Byrd tool website has the shelix head and bearings for one stop shopping. I am waiting for a quote on my old Minimax FSB 35 it is a bit of a bastard machine but they should have the Delta in stock. Prices are also listed on the website.
I have a Grizzly 8" with the Grizzly carbide spiral cutterhead. I also have a 20" stationary planer with the Byrd cutterhead. Both do a tremendous job on every wood I have used. I have used them on several varieties of Oak, Walnut, Figured cherry, Locust, Elm, poplar, cedar other common woods and some exotics. Some of the (to me) benefits are that if you do hit metal or something that will chip a blade, you can rotate the carbide cutters damaged quickly and be back in business. These cutterheads also eliminate any issues as far as setting the blade height. They also last several times longer than the steel blades on each of the 4 cutting edges.
They are one of the things I would spend the money for again willingly. I have actually ran an assembled panel and frame through the planer which meant the cutting was cross grain on parts, all the surfaces planed cleanly without tear-out!
As had been stated my Byrd head came with bearings fitted, I purchased the Grizzly joiner with the head.
However, if you don't wish to spend the money and do find the bearings are bad, I am sure you can measure the existing bearings for thickness, bore and OD and find replacements at a bearing manufactures site. NO machinery manufacture that I am aware of makes their own bearings. Having worked in the industrial manufacturing field as an Engineer for near 40 years I am confident of that statement.
I have sent an E-mail to Byrd asking for advice and to see if they know and ship the bearings. Meanwhile I will investigate the situation more closely and track down the grumbling. I dislike doing shop maintenance. I would rather work IN the shop than ON the shop. (and it looks like it)
I was griping about having to sharpen the planer and jointer blades "EVERY time I turn around". Turns out I had written the date on them each of the last two times I sharpened them. Three years ago and three years before that. It seems like a terrible burden.
My thinking was that if I have to disassemble the head anyway to replace the bearing I might as well do the improved head at the same time. At my age, a set of carbide cutters might be a lifetime supply.
