Bearing Quality?
Bearing Quality?
Bearing Quality?
tom
I will be replacing the cutter head bearings on my Inca 550 Jointer/Planer in the near future. But I was wondering when I shop for bearings are there different "qualities"?
Thanks!
Re: Bearing Quality?
Rick W
I would try Accurate Bearing. Call them with the bearing number and ask for Lynne. Ask for a good quality American or Japanese bearing. Avoid cheap Chinese bearings.
Bearings come in different classes, depending on the precision required. Since you don't need high-precision bearings, a bearing of the class original to the jointer will be fine.
From the horse's mouth *LINK*
I just spoke with Jesse Barragan at Eagle Tools in Los Angeles. He's probably the most knowledgeable person on Inca machinery questions. He suggests that you make sure your new bearings have the same universal bearing number that is stamped on the originals and that they have rubber seals. He also said that Japanese and German bearings are of a higher quality and last much longer than run-of-the-mill cheapo bearings.
On another note, Jesse said that you need to be very careful when changing bearings on this machine, because the castings around the bearing housings are a weak point of the machine. I didn't get any specific instructions on how to safely remove and reinstall the bearings, but it could be tricky.
If you would like to contact them to either order new bearings or get some additional information about proper precautions, you can visit their site at the link below. Tell them I sent you.
Ellis Walentine, Host
Eagle Tools
Just been through it
What is of greatest importance is the seal, which in turn determines how fast the bearing can spin and not destroy what ever the seal is. For a dusty situation you will want the best seal consistent with RPM limitations. Your bearing store should be able to provide advice to the correct bearing.
Agree ... plus
Ron in Sterling, CT
As a retired seal manufacturer, make absolutely certain that the seal is rated for whatever rpm your shaft is turning. Most all standard seals appropriate for this application are made of nitrile, but have different interferences, which in turn creates heat.
I agree with the comments about bearing quality. Get good ones. NTN, & NSK, (Japanese)make quality bearings, as does SKF (Sweden). I would either consult the original equipment Manufacturer,(in Ellis's link) or a quality bearing house for recommendations.
Re: Agree ... plus
tom
Thanks for the replies! I was able to pick up new bearings today at Bearings Dist.. I got NTN, the same as the original. They are installed and the machine is almost back together!
