The Floating Credenza - Base Frame
Brian Holcombe
Good morning! The Floating Credenza is now residing at New Hope Arts gallery in New Hope, PA but it is not quite completed in it's electronic form. This post details the process of building the base frame for the credenza. I was hesitant in building a baseframe but ultimately happy that I did so, upon seeing the gallery I quickly realized that installing a cabinet into a wall was quite impractical. I look forward to your comments.
https://brianholcombewoodworker.com/2016/11/10/the-floating-credenza-base-frame/
Re: The Floating Credenza - Base Frame
commments and questions
I think the cabinet looks complete sitting on its base. Personally, I prefer this arrangement over fastened to a wall. Is there any means of securing the two pieces together?
I would have used Transtint black over leather dye only because I know the Transtint is a premetallized dye that is highly resistant to fading and I don't know anything about leather dye. I also would have used cheaper soft or hard maple instead of expensive cherry to stain black.
The joint on the top rail is unconventional by western Period standards. Never seen a bridle joint in this application. More commonly it would have been M&T or dovetail. But with the stretcher close below it hardly maters what joint is used and bridles are easy to cut.
I have an art design critic friend who happens to like and know furniture. Her favorite phrase is "what is that about" when she encounters something out of place in furniture. The phrase came to mind when encountering the massive stretcher that seems to have no purpose. Is this some Oriental design element my western eye is unaccustomed to? It just doesn't seem to belong with the rest.
Re: commments and questions
Brian Holcombe
Thanks for suggestions on the dye's Bill, I'll certainly keep that in mind for future use.
The only disappointment with leather dye, was that, being alcohol based, it picked up when I went to shellac the frame. Not a problem really as enough of it on the rag along with the shellac cured the issue.
In hindsight a dovetail would have likely been a better choice, but all things considered the bridle joint worked out just fine. To be completely honest I was working something to the effect of 12-14 hour days to get this cabinet ready for round-two of the process of its judgement by the show's staff and so I chose the simplest joinery that would accomplish the task at hand.
Also, I forgot to add commentary on this part, and actually plum forgot about it...but I pinned joints.
Sean Troy
That's a beauty !
Brian Holcombe
Thank you!
The close spaced stretcher below would hold it together bridle joint or not, so I certainly had no reservations on the engineering....just saying what one would find for something similar in 1780. I would have used a haunched M&T myself.
Wood working is supposed to be fun. Try to avoid deadlines. :)
I have mixed opinion on pinning. If the glue fails it keeps the piece together and maybe avoids the dreaded nails one finds in antique repair....maybe. But if the glue fails it would be best to make the repair and not be encouraged by the pin to postpone. Truthfully, I am probably too lazy to deal with pinning and rationalize a reason not to. I don' t much like the looks of pins when I can see them.
In any case I do like the addition of the base. It yields a handsome piece. The rest looks too big to float.
Brian Holcombe
Thanks Bill, I appreciate your thoughts. I think the dovetail is a good idea, sometimes my thought process just loops through certain solutions when I'm planning out a project and they're what ends up happening, especially when working on the fly.
I tend to avoid working with hard deadlines, next year I will simply submit whatever I have around the house, which will likely be some shoji screens or whatnot.
I have similar thoughts on the pins, but in this case they seemed appropriate.
