A New (to me) Woodworking Idea *LINK*
John McGaw
I don't recall seeing this here or anywhere else. Apologies if it is not new news. It reminds me in a way of bentwood boxes from the Pacific Northwest first nations.
New Drawer Fabrication Technique
John McGaw
Re: A New (to me) Woodworking Idea
Ed Wozniak - Buffalo, NY
I wonder how the tightness of the joint varies with plywood thickness. Would the blade that works with 3/4 inch plywood work with 47/64 inch or 23/32 inch plywood? Even 3/4 inch plywood has a tolerance. I wonder how critical the thickness dimension is.
Miterfold *LINK*
You're right about the First Nations use of this type of joint. It goes back several hundred years at least. The link below shows some examples and illustrates the way the joints were cut. These were customarily made of solid Western Red Cedar, and were steamed to relax the wood fibers before bending the corners.
Fast forward to manufactured furniture today. "Miterfold" drawers have been around for decades as a cheap alternative to more substantial drawer construction. Typically, the miterfold blank is simply a piece of 1/2" or 3/8" flakeboard wrapped with vinyl sheet and then crosscut with V-grooves at the corner locations. Assembly couldn't be simpler: put glue in the Vs, fold up the sides around a bottom panel that is held in a groove in the blank, and nail or pin the final corner together. A fillet of hot glue around the underside of the bottom panel locks things in place firmly.
Bentwood Chests
EdSnow
It would vary a lot. Also, notice it requires some clocking with respect to the edge to make the corners fold, if you just cruise round the perimeter it wont fold in the corners, you have to flop sides of the fence to make it work. Seems error prone when one is in autopilot also a guaranteed way to make the sides a different height.
A true miterfold 45/45 without quirks doesn't care about thickness as they are run either on an overhead beam saw (rare) or platen type router, nor do they care about orientation to a fence. Reference datum is constant (the bottom) no matter the thickness and 45 is always just 45 regardless. You could run true miterfold tooling on a table saw using blade elevation to accommodate the thickness changes but you can't swing a large enough tool in a 10 inch saw to get it done on much thicker than a 1/2" drawer side and even that would require a fully custom tool with relief for the arbor nut.
His joint may have a slight mechanical advantage due to surface area.
