Re: Supermax drum sander
Grant Smith
I have a Supermax pro 25 drum sander (single sanding drum). I bought mine used at an estate auction about five years ago.
It is a great machine, well worth the investment. I had previously owned an open ended performax, and had issues with the flex in the drum causing un-flat surfaces.
You may already know that Supermax is a company that bought the rights to the commercial level sanders that were formerly sold under the Performax name. Supermax is still in operation, obviously. The same machines were formerly marketed under Performax name, and consumer line was bought by Menards, and now exists as a store brand, though they don't seem to carry the old line of smaller sanders. I say all of that because it means you can look for the same machine under the Performax name if you are considering used.
I have contacted Supermax a couple times for small items and with questions. They are a class act, know their products well, and I have had no issues with them.
Now, about the sanders performance. I get all of my lumber from doing logs to lumber, and as such my starting point for a project is jointing, planing, and surfacing lumber. I chose the closed ended shop pro 25 because I knew it wouldn't have issues with flexing. And, at 25" capacity, I figured it could meet me needs for the most part.
When I purchased the machine, it came with lots of the brown colored aluminum oxide media. I found that, especially with the finer grits, the paper loads up easily, so I have been purchasing exclusively Klingspor blue Zirconia media, with much better results. No complaints.
My machine is old enough that it doesn't have the automatic feed control feature, and instead is equipped only with a feed control knob. I have learned that more light passes at a higher feed rate is key to preventing burning of stock. I think this works because the wood doesn't have time to heat up.
height adjustments are easily made. I have found that a policy of no more than an eight of a turn of the height crank should be made to avoid overloading and burning. This is with 36 grit paper, and the finer grits work best with even finer adjustments. I use my sander only up to 120 grit, and use a fein 6" orbital from there.
Many will tell you that these sanders are sanders, and not dimensioners. True, unless you learn the fine art of feed rate balanced with height control, and even more true unless you discover the 36 grit paper.
I use mine to dimension large slabs fairly often these days. It does an admirable job, given careful in feed and out feed roller placement. I have flattened natural edge slabs of Cherry up to 7.5' long, 22" wide and 2+" thick, given careful management of things and a helper.
Regarding power. The motor on mine is a Baldor branded unit, and really doesn't run out of power. No comparison lower grade motors of the same HP rating. That said, if you bungle things and take a pass that is too heavy, it will trip a 15A breaker. I have also found that it can trip the same breaker on startup, but a workaround is to always start the drum first before the feed motor.
I do plan to change mine over to 220VAC when I get a chance to sort out what it takes to accommodate the feed motor and electronics.
Dust collection is fine using the 4" dust fitting, though I have it connected to a 6" hose and duct system with an Oneida cyclone with 2HP motor. This way there is only a small distance that the dust must pass through the resistance of a 4" line. Pretty much no dust escapes with this setup, though some bark chips that fall off live edge stock doesn't get grabbed.
Mine came with a shop built mobile base, and rolls fairly easily. There isn't a more stable machine in the shop, save for perhaps the cabinet saw.
I have had no issues with mine to date, and have only contacted the company to ensure parts were available before I bought, and to inquire about upgrading the feed roller to the auto setup. This was cost prohibitive to make the change, so I have learned to use the manual feed adjustment effectively.
The machine sands squarely, flat, and is equipped with adjustments in case such is eventually necessary.
I would recommend the machine, especially to a person who has used other drum sanders and understands the limits of their use.
http://www.supermaxtools.com/products/wood/shoppro-25-drum-sander/
Regards,
Grant in Iowa
