REAL MILK PAINT
Lesson Learned
Lesson Learned
Lesson Learned
DaveNM
I'm sure all the old timers and pros know this one: I wanted to make the toy battleship (Wood Magazine, Nov 2016). So, I ordered a nice piece of 8/4 cherry, 3 ft long. When it came, I looked it over and decided to put the smoothest side up, the other side still showing marks from the planer, I put down. I thought this would save me some sanding effort later. So, I affixed the template drawings to the top side and proceeded to cut and drill the rough hull.
Now, it's sanding time. I pull the paper off the top and start -- only to discover:
1. I had put some exquisitely beautiful grain on the bottom.
2. The top had a few ground in black marks I couldn't sand out with P60 grade paper.
Next time, I won't be quite so quick to assume the project process until I've looked at everything I can think of and thought it through.
Re: Lesson Learned
Re: Lesson Learned
John McGaw
What will show up in a piece of wood is always a surprise and not always a good one. I've wound up with more than a few table tops where some of the wood with the best appearance showed up on the bottom. Once I sawed a finished table top apart at the seams and flipped a piece and re-glued and re-sanded and re-finished.
