Another Serwin Williams Lacquer Question.
I posted about using Sherwin Williams CAB Acrylic Lacquer and got favorable responses. Went to the store and bought some. They printed the data sheet that went with it for me. Read It later and it recommends matching Vinyl Sealer as a primer coat. Do you use it? Do you have to? (I am finishing a bed but will use this as a general purpose finish.)
And do you use Sherwin Williams lacquer thinner or will any old lacquer do?
Re: Another Serwin Williams Lacquer Question.
del schisler
i use M.L.CAMPBEL lacquer all the time for yrs now, i use the sanding sealer and than the top coat , works very well this company is own by sherwin williams but they make their own product . and i use their thinner also , i guess both are very good
it recommends matching Vinyl Sealer as a primer coat. This sealer with keep the finish "water white". You can use the lacquer as sealer but I will not sand easily.
And do you use Sherwin Williams lacquer thinner,,,,any thinner will do
all M.L CAMPBEL sealer , thiner, top coat
Clint Searl
Clint Searl
The vinyl sealer is superfluous for one-off projects. CAB is self sealing. It's also most amenable to reducing with acetone.
Thanks, I sprayed the bed today
It came out well. The spray dried quickly, leveled nicely and was easy to scuff sand between coats. I like it so far.
