Kickback damaged my Makita CMS
Tim Greif- west of Chicago
A couple weeks ago, I had a pretty severe kickback on my Makita LS-1220 12" CMS. I was trimming a 45 miter on a tall piece (3-1/4") of oak base molding held vertical against the fence. It happened so fast, I don't know exactly what happened, but it was severe enough to rip the piece out my hand, bend the sub fence, break the main fence and bend the blade. No injury to me but it did a number on the saw. I just put on a new fence and sub-fence and got a new Diablo 12"-80 tooth blade. When I went to test it, I noticed I now have a very slight blade wobble. I have a couple different blades. It doesn't matter which one I use, I can see it when I start and stop the saw. I'm thinking I either bent the arbor or the blade washers. I've already thrown about $90 in parts at and don't want to keep throwing money at a lost cause. I'm torn between trying to salvage this one or just buying a new Makita LS-1221 ($298 on Amazon) Anybody ever have a similar issue? Any advice or insight would be appreciated.
Re: Kickback damaged my Makita CMS
Should be ....
Brian Roberts
Fairly easy to determine whether the washers are bent (cheap and easy repair) or the shaft is bent (not so cheap...or easy.....repair)
In looking at the parts diagram at:
http://www.ereplacementparts.com/makita-ls1220-compound-miter-saw-parts-c-97_98_99_493.html
The spindle and flanges are where I would start looking for damage.
It looks like the spindle is independent of the motor shaft....so not as bad as my comment above suggested.
At any rate...print out a copy of the parts diagrams (if you don't already have them) and start ripping it apart.
I think any damaged parts will be fairly obvious....with a close and careful examination.
I would think this is a good use for a dial indicator. Even a cheap one form Harbor Freight. Since I don't have even a cheapy, I would use something like a pencil. Unplug the saw for safety, clamp a sharp hard pencil to the fence so it touches or very nearly touches the end of the shaft and gently rotate the shaft. With a bright light you can see even a few thousandths. The threads might make it a little confusing.
You can do the same thing with the blade. Mark a tooth with magic marker, Clamp the pencil so it very nearly touches the side of the tooth and gently rotate the blade.
Now you may know more than before.
By any chance, did you have the offending piece loosely or poorly supported? (a mistake I have made.)
