A55 Smoothing Plane
Shortening B'meyer to the right.
Tom Dunlap
I bought a B'meyer fence from another forumite. It's the long rail model. I need shop floor space more than I need that capacity 7' to the right of the blade.
My plan is to cut off some of the rails...but...what is a good capacity?
It was rare that I used the other rail/fence setup to rip sheet goods. Using a guide for my circle saw was easier than rasslin' a 4x8.
It seems like 30" capacity would be a good compromise.
Any feedback?
Tom
Re: Shortening B'meyer to the right.
I have the shorter model of the Bsmier. It allows a 30" cut (I think) to the right of the fence. I do all kinds of stuff including making furniture and house flipping. The 30" capacity has been fine except on one or two occasions where I sneaked it out to maybe 31". Having said that, my previous set of rails were homemade and I allowed for a 36" cut to the right. My goal was to get 34 1/2" to be able cut cabinet ends. Back in the day I made cabinets to work my way through college. I have not really missed it, but I still think its a good idea.
Glad to hear the rails are going into service, hope you like yours as much as I like mine.
PS....
I mounted an extension table on the right side of my saw. Its two sink cutouts glued together back to back with mounting bolts glued in between and a cutout in it for a router. Lets me use the fence with the router. Actually I use a clamp on fence with the router occasionally to let me keep using the fence with the saw.
I have lived with just over 24" and never had need for greater. But, I don't work plywood much.
I don't have a B'meyer.
I do have a 50+" capacity to the right of my saw blade.
Do I ever use it? Yes.
I do have a set of clamp guides (104", 50" and smaller) that I use to break down plywood. There have been many occasions where I had to rip something down to 40" or 30+" - and for that I use my cabinet saw. YMMV of course.
By all means, cut it down to a length that will suit your shop - but do think about what your minimum distance carefully.
Bruce, a MN Galoot
I have 30" capacity on mine, and it's pretty handy. My last saw just barely had 24" and it served most needs, but there were time I wanted more.
Jim DeLaney, Austintown, Ohio
Mine's cut to allow 36". I've never needed more than that. Plywood gets cut with a circular saw - or lately, my Festool 55.
Gary Smyth
For $1.00 per cut my lumber supplier will cut sheet goods to whatever size I want on their full size table saw. 95% of the time they will do it while I'm standing there. It just takes a little planning for project dimensions.
My contractor's Jet cuts to 28", but for my applications I sure wish I could get full 32" out of it. Don't know why that number regularly comes up for me, but many times I wish I had that bit more capacity for stuff.
walta
If you are anywhere near St Louis I have a spare short rail I will trade with you.
Walta
Tom Dunlap
A trade??? Hmmm...something to consider
I'll mull this over
Send me a note
treenail4 at gee mail dot com
Robin Corell in Atascadero
The rail on my Biesmeyer is 7' long but only 5' is to the right of the blade which gives me a 53" cut capacity to the right. I don't use that for sheet goods but I do use it with my cross cut sled by clamping a 1" thick block of wood top the fence for multiple cuts. I rarely use the fence on the left side of the blade but often slide the fence to the extreme right rather then lift it off the saw.
Keeping the 53" capacity may seem like a bit of a floor space hog for something that is rarely done but I get double duty of that space by using it as my router table. I use a separate fence of my own design that uses threaded inserts in the out feed table and brass locating pins and sockets so I can remove the router fence and reinstall it and get 100% repeatable results.
I also find the large out feed table handy for large layouts and even use it as a work space on occasion since I opted to have a fully functional cabinet saw over a large traditional style work bench. for reference my shop is 13'x 19' and to rip anything longer than 4' I have to open a door. My set up would probably drive many on this forum nuts but my table saw is one of my least used tools, I tend to use my band saw, disc sander, and spindle sander more that my table saw.
