Way OT - Need a new shovel
Jerry Nicholson
The wood on my best long handled spade is coming apart inside the metal ferrule. I don't understand why it is failing so soon - I have only had it for 45 years or so. Does anyone have a recommendation as to where to find a high quality long handled spade? The folks I bought this one from are long out of business. I would like it to last the rest of my life. Of course since I am 80 that might not be too tough a requirement.
Jerry
Re: Way OT - Need a new shovel
The title says shovel and the text body says spade. What is it? I have never successfully replaced a wood shovel handle. I have, however, put a pitch fork handle on a spade fork with outstanding success. No more stooping to spade the garden and flower bed. I get handles at the flea market but I suppose a full service hardware store would have them.
I like the higher quality tools sold my the local farmer's co-op. Sometimes Tractor Supply carries good tools.
However, I've made new handles for several tools, including one for this shovel and one for the shuffle hoe. (The shovel handle is a little shorter than standard since that was the longest I could "handle" (ha) on an earlier lathe.)
Years ago I cut a number of hickory blanks for long and short tool handles. The longer handles are a little tricky to turn on the lathe without a steady rest. A shovel handle is also a little tricky since it curves on the end to fit into the curved steel socket. I carved on it a little, boiled the end, and forced it into the steel. Still good 8 years later.
If buying a new shovel, I would definitely get a non-wooden handle, fiberglass or aluminum. Note that some handles LOOK like they are not wood but they are simply a wood handle in a plastic tube.
JKJ, That is a good all-purpose photo.
Keith Newton
I think that is the same one you posted when I ask about overalls, and you were pushing Big Smith's I believe.
What else do you use it for? ha
EdSnow
Check out House Handle of Cassville Missouri. Have a mail order arm.
https://www.househandle.com/about-us.htm
New shovel or new shovel handle?
John in NM
The handle is fairly easy to replace - soak in water over night, orient the kerf in the handle so that it lets the two halves more easily follow the curve of the shovel socket. Hammer home & pin. Shovels are easy compared to an axe, hardly any fitting needed because the socket on the head is open at the back.
I will admit that I also have a fiberglass handled Ames spade. Bought it because the spade head was pretty heavy duty and that's needed when the ground here is dry. I mostly use it for pulling loco weed - got to go deep to get the bulk of its root.
David Bair
Ames sells a line of fiberglass-handled shovels. The handle lasted longer than the blade in my last one.
'glass for me
Tom Dunlap
Don't throw rocks or dirt clods at me! After all this is a woodworking forum
When I was running my tree care company I'd replace shovels too often when the wooden handles broke. Then I bought two #2 True Temper shovels with orange fiberglass handles. They outlasted a few employees and I still have them. They survived a LOT of prying too
Over time I've put 'glass handles on axes, mattocks, splitting mauls, sledge hammers of many weights and a couple of 'smashing hammers'
Tomp
Re: JKJ, That is a good all-purpose photo.
To show off one of my WoodCentral hats. And to show that yes, we DO have actual flowers on the porch for a little while before we kill them.
Shovel or Spade
I was 60 years old before I learned that what I was calling a shovel was a spade and vice versa.
Seems backwards to me but evidently the shovel has the point and a curved "scoop". The spade is flatter with a straight tip. To further confuse the issue, the blade on my favorite spade is long and narrow with a round nose.
Re: Shovel or Spade
Jerry Nicholson
So then I want a shovel. I just want something that has a long handle and can be pushed into the ground with my foot - or with my soil sometimes it has to be pushed into the ground by jumping up and getting one foot on each side of the shovel. Or spade. Or something! But I may be too old for that maneuver!
Jerry
Learn something new --
Jerry Nicholson
In looking at shovel on the BORG websites, I just discovered that the shovel that I have known as a "sharpshooter" for the last 70 or so years is known as a drain spade! How about that!
Jerry
more confusion
To me a spade is typically a short handled tool with four prongs on the end from breaking up soil. It is used for "spading" the garden, digging potatoes and the like.
Seems you all are referring to some earth digging/moving tool that I collectively call a shovel. Success in replacing a shovel handle depends on how it is attached to the shovel. If the handle is entirely wood that goes into a springy socket I have had no luck getting it tight again.
A simple solution is to visit a flea market and buy a used one. If buying new get a fiberglass handled shovel. They last decades until you run over it with the truck :(
Calling A Spade A "Spade"
or what you will, but what you describe is a "fork" or, more properly, a "potato fork"
Re: Calling A Spade A "Spade" *LINK*
Tom Dunlap
To me...not an authority...shovels have pointed ends spades are square nose
Point or square
OT, but how to get broken handle out of socket
GolfSteve in Calgary
Maybe a bit off topic, but I broke my "transplant spade"....you know the stainless ones that Lee Valley advertised saying "the handles made in Britain are very strong, but are not intended for prying out tree roots"...
Anyway I was prying out a tree root and broke the darn handle right at the top of the socket. This shovel has quite a long and fully enclosed socket. I cannot get the broken stub out of the socket. There is nothing left that I can grab with plyers. I've tried drilling out what I can, but now I'm stuck.
Any advice?
p.s. I've already removed the two metals rivets that, from the way they were bent, appeared to be drawbored into the handle stub.
Re: OT, but how to get broken handle out of socket
David Bair
Burn it out.
Paul in NJ
First I would try to shrink the handle. Maybe placing in a 200 degree oven for a couple of hours when wifey was not home :D Or maybe in a barbecue grill. Then I would try screwing in a long lag bolt and using that to pull it out.
regards,
Paul Dzioba
Paul in NJ
You will ruin the temper if you try to burn it out.
I'd burn it out. As far as the temper goes, I don't think it matters, at least not for the socket. Lay the socket in a charcoal grill and let the blade stay cool. Or in the coals in your fireplace if you have a gas grill.
I drilled out as much as I could then directed a propane torch inside to crisp and degrade the wood, then pried out pieces with a big screwdriver. (A big screwdriver is technically a professional pry bar, right?)
Ralph Lipeles
You can buy replacement handles. First remove what is left of the old handle and handle retaining holes. You usually have to bend the handle end so that it will match the shovel shape. Put that end in boiling water for 10 minutes, then insert it solidly into the shovel head. Let it sit for a few hours until it cools down and retains the shovel shape. Remove it and let it dry out for a few days. Next, put it in place and drill for the retaining rivet holes. Any steel rod or nail of the right diameter will do for the rivets. Cut them a little too long, and peen them in place. You should be good for another 60 years.
Kneale Brownson
Kneale Brownson
Or that the gray whiskers give you some authority. (what hair I have left turned gray years ago)
