Air filtration unit up to a suspended ceiling
CharlieL
Air filtration units usually are hung from the ceiling with chain. I have a room that has a suspended ceiling and I'm mounting it to the ceiling joists, through the suspended ceiling and to the unit. I really didn't want to butcher up the ceiling panel trying to pass a chain through it at an angle, I want a cleaner look, plus be able to remove the panels without disturbing anything, or being a lot of work to do so. I decided to go with threaded rod and two brackets fastened to the ceiling joists. I'm glad that I thought about it for awhile because in the end I think that it's going to turn out pretty darn well.
Re: Air filtration unit up to a suspended ceiling
Dave Nichols
I had the same problem and also used the threaded rod to hang it, I have just enough below the ceiling to store the wands for my shop vac.
CharlieL
Dave, are your ceiling panels still removable ?
When I built extensive and complex drop ceilings for my dads place I had some that were so tight up against things that they could not be either installed removed the normal way. I managed this by positioning the hanging wires so I could slide the panels horizontally to a more open space. Removing one then required removing two or three. I don't know if this method would work for your situation without seeing it.
CharlieL
John, things are a little tight as far as space goes. I have a 4 ft fluorescent 4 bulb fixture on one side, and a beveled ceiling recess for a window on the other, but I believe that it will work. My question to Dave was on the placement o0f the threaded rod coming out of the ceiling. If I just put the rods through the ceiling panel, there is really no way to fully remove the ceiling panel once everything is up. What I decided to do is run the rods through the grid. I added two pieces of grid to the 2 ft X 4 ft panel section and run the rods through the grids and out of the way of the panels for the most part. Now I should be able to remove the panels without much hassle. I also added a electrical outlet to the celing grid work. I put a picture of the setup in my website. https://sites.google.com/site/deltacontractorstablesaw/
Dave Nichols
I put the rods through the panel, it's not removable, since my shop is almost 1000 sq. ft. I wasn't worried that one panel wasn't able to be removed.
CharlieL
Dave, for my situation it's easier for me to level the air unit with the panel above it out. Then when I'm done leveling, I can install the panel.
CharlieL
As mentioned earlier I also added a electrical outlet to the celing grid work, useing a ceiling grid work electrical box mounting bracket for the task.
Re: Air filtration unit installed
CharlieL
Well it took some time, but I got it done, and I'm happy with how it came out. Can be seen on my website. https://sites.google.com/site/deltacontractorstablesaw/
Re: I give up.
Re: I give up.
Joseph Mulherin
just type in "www.google.com"; then the "Deltacontractorssaw"; then "air cleaner installation" and you should find it to view.
Re: Guess again Joseph
CharlieL
You won't see much information there about how I do things anymore. It's not worth the time and aggravation to me. Good luck.
Joseph Mulherin
Well, at least you are satisfied with the installation and that is the best requirement we all have in our finished work.
Go to YouTube and find a guy who installed his own using just eyebolts, S hooks and a lot of chain....all by himself....no help...
Re: I guess you missed my point  Joseph
CharlieL
Or you didn't read my first point. I didn't want to use chain and hooks. With threaded rod it's a lot cleaner look coming through a suspended ceiling. I was able to do it all by myself, no problem, but who cares right ? Whatever !
