Wood Bleach Question
Hank Knight
I'm looking for a strong wood bleach that will take the color out of maple. I tried oxalyc acid with borax as a neutralizer, but it had no effect on the natural color of the wood, even after 3 applications. It did, however, completely remove an ugly black rust stain from my maple bench top. I'm looking for something that will remove the color in the wood itself leaving it pale neutral color. Strong hydrogen peroxide (30% or greater) seems to be the ticket, with sodium hydroxide as the neutralizer, but I can't find the peroxide. Kleen Strip sold a two part wood bleach kit that was based on hydrogen peroxide, but it has been discontinued. Anybody have any suggestions? What have you used successfully?
TIA,
Hank
Re: Wood Bleach Question
Chuck Kettler
30% peroxide is available at most swimming pool supply stores.
Or
beautician supply stores
correcting the chemistry
Hydrogen peroxide will be more effective in a basic chemical environment. While I have no experience bleaching wood, I would think that the bleach would be a mixture of some amount of each component.
Hydrogen peroxide does not need to be "neutralized" but the sodium hydroxide probably does need to be neutralized. I can imagine some reactions between it and any of the common finishes that would not be good for the finish.
30% hydrogen peroxide is not to be trifled with. It is not hard to make explosive and/or flammable mixtures with it if it finds the right material to react with.
Re: correcting the chemistry
John C Lucas
Ive done a.lot of bleaching using the Klean Strip. I quit using the neutralizer because i saw no need for it and i havent had a problem with any finish ive used. To bleach Maple to white it will take 3 to 5 applications. You have to let it almost dry between coats to see what its doing. Any finish will darken it some so you need to bleach lighter. Water base poly seems to yellow the least.
Hank Knight
Thanks for the help, everyone. If I can find the H2O2 locally, I'm going to give this a try. I'll post results.
Hank
John McGaw
The original 'rocket belt' used hydrogen peroxide as its 'fuel'. It pushed it past perforated disks of zinc (IIRC) in the engine which flashed it into steam instantly effectively making the rocket belt a sort of steam engine. Dilute hydrogen peroxide won't react so energetically but it can do some odd unexpected stuff.
