I have a John Deere 22 hp lawn tractor that is sick. (This is actually wood related because I was pulling logs around the yard when it got sick.) It overheated and shut off. I started it after it cooled down and it ran for awhile, but now when I start it it runs for a few seconds then shuts down. Any small engine mechanics in our group?
I'm not a small engine mechanic or anything in that caliber but I'd suspect a dirty fuel line ,I would empty the gas tank and remove /clean it,then the carburetor is next.they way you described (that it runs a few seconds and shuts down) tells me that the engine burns the available fuel until it starves for more ,something is stopping the flow of fuel.
Is it a D-140. The heat might have taken out the fuel pump above the hose near the filter. Also as stated above check air filter. Take the air filter off and see if it runs OK. The fuel pump and filter can be checked by pulling the line going to the carb off turn it over and see if fuel come out. The fuel pump (if it is like on mine) is a round piece with three hoses coming off of it. Heat kills rubber and plastic check all the hoses.
An old mechanic once told me something about engines I never forgot:
If it has good compression, air/fuel mixture, and a spark at the right time it HAS to run, "it don't have no choice." Checking these one at a time usually narrows down the problem for me.
I hate to tell you this, but if it's overheating and shutting down, you most likely lost the crank bearings. I would immediately stop running it until you open the case and check the bearings before it does irreparable harm.
Because it will run when cold, I don't think you have done serious damage yet. But you do need to get it looked at before trying it again.
You can find replacement cranks and rod assemblies on eBay fairly cheap.
Ouch, but considering how it overheated I suspect that's what happened. It got hung up on a rock and the engine pulley was grinding against it until I realized what was going on.
Not to be argumentative, but, how did you determine that it overheated vs just quitting for the first time due to fuel supply (or whatever the cause is found to be)?
It is realy unusual for a small engine to overheat unless airflow is blocked or it is run under a max load for an extended period in really hot weather.
To put it another way, I really doubt it got hot enough to die, rather it died because the fuel supply was inadequate. It restarted, not because it cooled off, but because The fuel supply was reestablished, but not enough for continued running.
I always suspect water or other contaminate. Drain some gas from the tank tank into a glass container, let it set for several minutes and examine. If it looks ok, change the filter and check fuel flow at the carb by removing the line and cranking the engine.
This reminded me of two things - one a generator started, ran very poorly, then quit every time. Examining the carburetor found nothing. Finally I ran a wire into the jet and found a buildup inside, perfectly smooth so it showed no visual problem. The wire fixed that engine.
Another time I bought a motorcycle from a disgusted neighbor for $1. He had tried for a long time to get it running, even took it to a shop. Would sputter but not run. I found someone had stuffed leaves and sticks in the tank and the fuel supply was starved. 20 minutes and it ran fine.
As mentioned before, I'd check for spark, fuel, and compression. Without a compression gauge you can put your thumb on the spark plug hole and turn the engine over to feel for compression. You can check for strong spark by watching the plug while holding it against a ground and turning the engine over. You can check for fuel to the carb (after checking for fuel from the tank) by removing the bowl and watching to see if gasoline runs through. If all these are OK, then look at the carb itself.
Water in the gas is in fact a possibility, although I usually don't get one to run even a little since more than a little water sinks to the bottom of the tank and gets sucked up first. I drain the tank completely into a container and look for water, if found drain the carb bowl, then try again with fresh gas.
