Broken blades
Doug Ridley
Anybody used Lee Valley's band saw blade splicing kit and what are your opinions on it?
Broken blades
Doug Ridley
Re: Broken blades
Dick Coers
I use one from Woodcraft, love it. I haven't bought a blade in probable 15 years. I watch eBay for blade rolls for a good price and then make my own. I hard solder up to 3/4" blades. Not sure if you are aware that a beveled skive joint has to be ground on the blade stock. I use a stationary disc sander with a miter gage to do that. Also just use a simple propane torch. Use lots of flux! I cut a piece of silver solder and just place it on top of the flux. Then heat from the opposite side of the joint. First the flux melts, then the silver solder melts and flows in. I use a Dremel with a sanding drum to sand off the flux and excess silver solder.
Re: Broken blades
Yonak
Doug, I have the Lee Valley jig. While I have nothing to compare it to, you could probably spend more money and get a higher quality jig, but I think it works OK.
As Dick says, you've got to grind matching bevels on the blade. I made a jig to help with this and, likewise, while you could probably spend money and get a better jig, mine works OK.
It doesn't seem to require tremendous accuracy. The silver solder does a fine job.
