Epifanes, along with...
Grant Smith
Hi Donna,
Many have tried to maintain a wooden door on a sun facing wall of their homes. Most have failed. Here are strategies to give it the best chance:
1. have an architect draw an overhang retrofit solution to keep the door out of the sun. This is the best long term approach. I say architect, because they are most qualified to both consider aesthetics as well as function.
2. Know that whatever the solution, you will need to periodically re-coat the door, perhaps annually, and certainly at least every two years or so to keep a film finish in place. I have a white oak door, sidelights, and transom that I have managed to keep up with 9 years now. It is the focal point of the front of our home, has about a 4' overhang, but still sees afternoon sun and Iowa winters, thunderstorms, etc. I purchased a "backup door", that I put in place when I did a major refinish. This is much easier work on sawhorses rather than with the door hanging.
3. Research finishes, focus mostly on marine finishes, as they are designed with sun and weather in mind. If you want expert advice, first read their website, then call Jamestown Distributors for the final advice before you make a purchase.
4. I did the above, then landed on Epifanes clear wood varnish. Much of my decision was based on a review of outdoor finishes with that product coming out on top. I wanted a clear finish, but your project will be more sun resistant with solids in it, so do your own research.
5. Know that patience and workmanship is key to a finish that will hold up. You cant expect to slop on two coats of something from the local chain store and expect a long lasting exterior finish. The product I suggested above works best with upwards of five coats, each thinned in decreasing amounts, starting with bare wood. It can be top coated without sanding between coats if you do the next coat at the right time.
6. Methods of work: I shook and stirred the product, decanted an amount needed in to a quart resealable jar, added thinner as recommended on the label. Applied coat #1. Next day, within the label recommendations, I did some mental math to determine the next amount of thinner while not wasting the remainder of the previous days varnish, added the appropriate amount of thinner and finish to the same jar, then re-coated. I proceeded like this for each of six coats. The first five coats were applied with a high quality foam brush (also available at Jamestown Distributors). The sixth coat was applied with a high quality brush designed for varnish.
7. You must have a passion for a great looking natural wood door. If you approach it like a labor of love, you can get great results. If you think it is a one day project, you will not likely like the results long term.
8. Re-coating will be necessary periodically. Usually more so on the lower portion of the door where driving rain and the most sun will hit the door. Read the can for recommendations.
http://www.jamestowndistributors.com/userportal/search.do?freeText=epifanes+clear+varnish&page=GRID&engine=adwords&keyword=epifanes_clear_varnish&gclid=CJeVxon35s8CFQgOaQodsTQOmQ
No affiliation with Jamestown Distributors, just a very happy customer. For a door, or even one with sidelights, you will not need more than a quart. Resist the urge to order two because the shipping rate is cheaper.
FWIW,
Grant in Iowa
