DIAMOND STONE USERS QUESTION fOR:
Mike Van Pelt
Diamond stones are expensive and the more I read the more confused I become. What size and grit would you recommend to get started? Thank-you!
Mike
Re: DIAMOND STONE USERS QUESTION fOR:
Joseph Piotrowski
I am also looking into these as well and have no idea
i suppose the wisest answers will involve "let your task at hand determine what you need" but i'm a sucker for kits. i'd rather have more than less on hand.
so i'm thinking of one of these kits:
https://www.sharpeningsupplies.com/DMT-6-Dia-Sharp-Kit-P404C112.aspx
Do you want to shape, sharpen, or hone?
I ordered a set of three double-sided diamond "stones", 2.5"x8" and got grits 180, 220, 350, 600, 1000, and 1200. (I have much finer ceramic stones for sharpening carving tools.) That was a good start for my use. These were surprisingly inexpensive.
Bought from Ken Rizza (Woodturners Wonders)
(678) 442 - 9454
I also got some CBN stones from him but I wanted diamond to work on some ceramic cutters.
BTW, I use these with Trend diamond lapping fluid: https://www.amazon.com/gp/product/B004NPIMU8
need more information
I have experimented with fixed diamond plates and loose diamond on cast iron for about 10 years. I can offer some information based on my experience but I need to know what you want to do with the diamond. No, this is not a dumb question. You might be restoring old pitted tools, doing the first refinement after hollow grinding, final honing, etc. and each task requires a different material. It many not even made sense for you to pursue diamonds. Personally, I rely on diamond abrasive.
Re: need more information
Mike Van Pelt
Thank-you! I will be using these stones to sharpen my woodworking chisels and my plane irons.
I like to finish the backs of my chisels so you can yourself in them. So I spend a great del of time honing the backs flat and mirrored. ( I Know that I am ...anal **stard)
thanks
Mike
Keith Newton
Hey Mike, I've been using them for a long time. When I bought them, they were just marked coarse medium and fine, but I don't know the grit numbers. Mine are 2" x 6" on about 3/16" plates, which I bonded onto wooden handles. I never use the coarse, so would suggest you save your money, if you have grinding equipment.
The reason I added the handles, is that it allows me to hone the knives on my 12" jointer about 4 times between grinding.
I bought a thin plate one which had holes cut out that wasn't worth having, so don't waste your money on those. I have wished that I'd bought the larger 2.5" x 8" that JKJ suggest many times, and will probably get them next time around, for what that is worth.
Try the Credit Card Size
kkruizen
You May want to try the Dia-Sharp Credit card size plates, I would suggest the Red (600) and Green (1200).
That way you can get try the feel of diamond stones for about $30.00 ( I think they are around $15 each) then if you like them you can get larger ones. One thing on the credit card plates you should mark the grit size right away it is almost impossible to tell them apart visually.
Thoughts on why not to follow this advice
Diamond coated plates have a break in period. They cut aggressively at first, then settle into a very long life of slower cutting. Hence, you will need to own and use a plate for some time before you know how it works and where it fits into your sharpening routine.
Some thoughts based on my long experience with diamond coated plates.
Personally I would find such a short plate useless for sharpening chisels and plane blades. I prefer a 12" plate for free-hand sharpening.
A settled in "fine" is a good step (what I use) after hollow grinding with a grinding wheel. I would fine it intolerably slow as a first step on a dull plane blade.
Ezlap makes the best plates. The diamond they use is long lived. They make a 12" plate.
Re: Thoughts on why not to follow this advice
jessecloud
I agree with Bill.
However, the credit card size plates are the cat's meow for touching up router bits.
I have four different sizes of diamond plates and a few misc diamond sharpeners.
I find the credit card size the least useful. I like the small Eze Lap paddle hones for my turning tools, special cutters, etc. (Got a lifetime supply direct from the mfgr once for cheap) For me these are easiest size to hold and control.
I like the larger plates for flattening and sharpening larger things. Those I mentioned from Rizza are 2.5"x8", thick steel (1/4"?). I think he can get them made to any size. I don't know how flat they are compared to expensive plates. I don't plan to use these with plane irons.
I used these today to work on some ceramic llama-shearing cutters, sharpening and repairing a chipped edge. Worked well at cutting ceramic, but as mentioned they are aggressive when new and must be broken in. I can see some diamond grit particles in the break-in slurry. Lapping ceramic appears to be a good way to break in these plates.
