Hardboard painting, luck of the draw
Gary Smyth
(Photo is manipulated to show line)
About a week ago I posted here asking if hardboard could be safely painted. Yesterday I found out that it can, but, rolled on paint can be a mistake. Hardboard is x number of layers of wood fiber mats placed in a press and squeezed and heated. Apparently, mats aren't always placed perfectly edge to edge when rotating alternate mats north south and then east west. When I painted 1/4" thick hardboard about three layers down the space telegraphed at the surface. The surface is flat -- no bubble I can feel. but well... you can see. Disappointing! There is no way to guess this would happen. I guess I suffered a lesson. The application is a top for a shop cabinet so not critical. I'll not use it again though.
Re: Hardboard painting, luck of the draw
Next Time
use a solvent-based sealer (shellac or lacquer) to "help" prevent the hardboard from swelling paint. Oddly enough, the same thing can happen with both water and slow-drying oil based paints. The tie/sealer coat can make a big difference in the final finish.
Re: Next Time
CharlieL
With the same type of board that is used to make pegboard but thicker, I've always sealed it with a coat or two of Poly, then let it cure a few days, sand it, and then apply a water base house paint to it. It's never failed me yet. The same goes for MDF particle board.
Re: Next Time, poly first
Gary Smyth
I debated with myself to do exactly that. Not knowing what could happen, I opted to paint first and then do poly on top to give me a harder, smoother surface that I could set heavy stuff on and keep more easily clean. My mistake, won't happen again.
