Link belt on a Sawstop?
Mike Farinella
Anyone use the link belts?
Re: Link belt on a Sawstop?
Why?
Dick Coers
It's just about the smoothest running saw I've used.
GolfSteve in Calgary
I've used link belts and I like them - but they are a luxury not a necessity in most cases.
For my tablesaw (a general international contractor's saw), the supplied belt was quite stiff and would take a set when not used for a while. On start-up the saw would wobble a bit until it got up to speed. With the link-belt it start-up a bit smoother.
I put a link-belt on my drill press. It made not difference compared to the rubber belt.
Industrially I've used them - because it was easier to install a link belt without disassembling a bunch of junk to get a new belt on.
I don't line them, so much less contact area
Dick Coers
I designed fan drives for Caterpillar tractors for years, and had to calculate hp and load capabilities, and wrap angles of V belt drive systems. If these segment belts do the job, the engineers on the woodworking machines must have greatly over designed them. If you consider the contact area of a V belt, compared to the contact area of the segment, it must be less than 1/2 for the segment. The horsepower rating of the sawstop was not mentioned, but if it's 3hp or more, I'd sure stay with the original designed drive belt style.
Re: I don't line them, so much less contact area
CharlieL
I have the Fenner Drives PowerTwist link belt on a Delta Contractors table saw, and a Rockwell Radial Drill Press. I'm pleased with how they work, I've never had the belts slip on either machine, so I don't understand how the belts contact surface area would be an issue. Also I've never understood the need for the added expense of a SawStop, or even a Cabinet table saw, and I've been mostly a hobbyist woodworker for about 30 years. Woodworking isn't profitable enough for me to spend a lot of money on unnecessary tools and machinery. I've been around long enough to know whats good, and whats imported junk.
Re: Links
Hi Dick,
I've used them for years, given the cheap-ass belt mfg'ers have been packing with their machines fort years. Put 3 on the JET Exacta, and 18" bandsaw, and the old jointer. They've all run smoothly, but I have no way to measure transmitted hp and I've never had a machine stall for lack of power. I'll grant they may be a bit louder than a top-line "X" belt, but with one machine running and my hearing loss, I couldn't tell the difference.
William Duffield
No. Link belts are designed to replace V-belts, mostly to reduce the vibration due to the memory of the v-belt. V-belts are incompatible with the type of belts and pulleys on the SawStops. As Dick noted, there is no belt vibration problem with SawStops anyway.
If you have a non-sawstop with vibration, and it also has cast pulleys, it's usually a good idea to replace the pulleys with balanced, machined pulleys when you upgrade to a link-belt, because the pulleys themselves are a major contributor to the vibrations that wear out the saw's bearings. Totally unnecessary on a SawStop, however.
I don't think your applications are using the hp
Dick Coers
A radial drill is much slower speed and much lower hp than the Sawstop. Closer requirements with the contractors saw, but still less hp rating. But if you're pleased, that's all that counts.
Bill Howatt
I have a Taiwanese 3-speed bandsaw and the regular V-belt would slip under heavy load on the smallest diameter pulley. The Link-belt performed much better.
I also have one on my contractor saw which is an ideal use for them because of the way the belt supports the motor. Certainly reduced the vibration.
Bill
no need
Bruce, a MN Galoot
Mine passes the nickel test with the stock flat belt, both start up and shut down. Plus, a link belt is noisier.
Mike Van Pelt
Dear Charlie:
With all do respect, I can assure you that Sawstop is not "imported junk" I have been selling and assembling
woodworking equipment for over 40 years. The Sawstop puts all other stationary woodworking equipment companies to shame with the best manual, best packaging, and attention to detail. Even if you removed the safety feature of the Sawstop, you can not buy a better made table saw today.
Yes, I am a hobbiest. I do not have to justify the expense to anyone. Woodworking is my passion and I enjoy using and owning good equipment. My brother-in-law lives to fish. He has money invested in his hobby as I do. Enjoy the hobby, and remember who dies with the most toys win!
Good luck and happy woodworking.
Mike
Re: Mike, my opinion of SawStop
CharlieL
Mike, I'm sorry but I've been a blue collar worker all my life, and when a company that has their product made overseas, and then wants to attempt to push it on everyone by law, it doesn't sit too well with me. Without the brake it may be a good saw compared to whats offered in todays world of new imported table saws, but I'll still take a older American made table saw any day over something thats made in China, Taiwan, Japan, etc. As far as tools and machinery, I have a few top notch items, but in most cases I bought them used, otherwise I could not have afforded it, or couldn't justify the cost. Trust me, I'm a tool and machine addict, and I probably have a lot more of them then I need.
