Recently purchased Wen 10 inch band saw from Amazon. Arrived in good condition but without an assembly or operating/adjusting information. Assembled easily and doesn't appear to be damaged in any fashion. I have tried to contact the company via their customer service number 888-4143-3565 but it is always busy. Any suggestions? I may need guidance someday in adjusting the wheels. thanks.
I must assume that you mistyped the phone number, and I don't know how to put you in touch with the company, but if you need help with anything, this is as good a place as any to get it -- maybe better.
A new saw shouldn't require any major tweaks, but getting the blade to track properly is a matter of tensioning the blade and canting the upper wheel so that the blade rides on the center of the tires. Before you turn on the motot, you can zero in on the proper canting by rotating the wheels manually as you fiddle the adjustment knob at the rear of the saw. (Assuming this is a typical saw configuration.)
Other than that, there shouldn't be any great mysteries. Let us know if you have any trouble.
