dust collector tubing
Bill P.
Can I use 4" PVC for the tubing running around the perimeter of the shop. I would use the typical flex hose to complete the connection to the machines.
Thanks.
Bill P.
Thanks.
Re: dust collector tubing
Dick Coers
You can use it, but we don't how big your shop is, what kind of elbows you will use, what kind of dust collector you use, how many drops, how big of thickness planer you will use, if you will use blast gates, etc. 4" will almost always choke down a dust collector. 1' of flex is like 10' of straight for restriction. Thickness planers and jointers need the most air movement and the dust collector should be located as close as possible.
BrianMonumentCO
If at all possible, I would ;
1. use larger diameter piping ( 5 inches or even 6 inches) depends on size of dust collector and shop
2. use larger sweep curves vs sharp curves.
3. Use blast gates to keep inactive parts of the run from being involved.
4. avoid any flexible piping as it counts as many feet of straight piping.
5. keep the piping level
In the past there were debates on whether PVC piping could cause static discharge type fires when used in dust collection systems. Some claimed it can, some claim no way. I wont get into the rest of the debate.
Just wanted to point this out. I use steel piping.
Ian Neuhaus
6" PVC tubing is always a better choice as it can move more than twice the volume of air.
The other consideration is minimizing the length of the ducting. The minimum distance depends on how your machines are arranged, but in most shops, minimum distance results when the ducting is run down the center of the shop.
Bill P.
I was just thinking I should have added some info on what will be used. I'll be hooking up these to a 1hp Delta DC, 13" planer, 3hp Unisaw, 12" miter saw all Delta. The Unisaw and planer are about 6-8 feet from the DC. A long run of about 18' with one 90 will go to a Bench Dog table and a 6" jointer. My shop is very small and everything is on mobile bases. I mounted the miter saw to a 10' formica countertop with a 6' and 3' Biesemeyer miter tables on each side of the saw. I also made an 8' benchtop with base cabinets underneath. I also have a Porter Cable drill press on a mobile base. With all that and some wood storage there's not a lot of room.
Bill Howatt
A 1HP DC is unlikely to move enough air in a 6" dia pipe to keep the chips from settling out. For a 1 HP, I think 4" or perhaps 5" is better.
Even though the flex is handy stuff, minimize it.
Bill
Bill P.
I'm kinda familiar with the affects of head pressure and friction loss in piping with water flow on our Koi pond filtration system.
BrianMonumentCO
Somewhere (I forget where I saw it) is a chart that shows how much CFM and inch diameter ducting each type of machine takes.
I mention this because your 1 HP dust collector may not be enough to handle your planer or jointer.
Stationary vs. Roll-around
Bill, as stated, your 1hp collector will not be moving enough air to pull a ductwork system like you envision. The smaller Delta and generic (samo) units come with casters so you can move the collector to the machine in use and use a short piece of hose for the connection. PIA, I know, BTDT.
I suspect you're at "Phase One" of the same dust control voyage many of us here have traveled. Phase Two is the central ducting you're asking about. Phase Three is upgrading the collector to a stationary 2hp with high efficiency filter. Phase Four is upgrading the ducts, and finally you wind up with a cyclone unit that'll suck you out of your skivvies.
Phase Zero
>>>I suspect you're at "Phase One" of the same dust control voyage many of us here have traveled. Phase Two is the central ducting you're asking about. Phase Three is upgrading the collector to a stationary 2hp with high efficiency filter. Phase Four is upgrading the ducts, and finally you wind up with a cyclone unit that'll suck you out of your skivvies. >>>
That's the best description I've read! Thanks to the wisdom from this forum and others for my new shop I managed to skip the intermediate steps and go straight from phase zero (shop vac) to a 5-hp cyclone with 6" ducts. Zounds, but that thing sucks.
james runchey
I built a dust collector from plans in Wood magazine several years ago, really worked great. I bought a 2 horse blower from Penn State for power. Sadly, I had to leave it behind when we moved to town. My new workshop is less than half of a two car garage with no room for a dust collector. Anyhow, with that unit, I used 6" PVC sewer pipe with 4" PVC drops, worked great. I would imagine the plans are still available somewhere. It was a great unit, badly missed.
Notes on Ducts
Use PVC "S&D" (sewer & drain) for your ducts; NOT the Sch. 40 stuff at the BORGs. You'll likely need to go to a plumbing supply or even a landscape/hardscape supply yard to find it. Thinner and cheaper but does fine.
Do not glue the joints; use aluminum HVAC tape to seal so you can get into the lines to clear any clogs or build-up of debris.
Make your turns using a pair of 45° bends plus a middle piece that holds them apart a distance equal to the diameter of your pipe.
CharlieL
A 1 hp dust collector is not enough CFM for a ducted dust collection system. For a ducted system you need atleast a 2 hp dust collector, and I don't mean a over rated Harbor Freight 2 hp dust collector. And there are different kinds of flex, the best being smooth interior wall that is made for dust collection.
