THE WOODRAT IS BACK!
OT Get odor out of Fridge?????
Friend of mine just bought a house at foreclosure. Been abandoned about six months with the power off. Everything was left in the refrigerator and its rotted and stinking. I have been lead to be live there is nothing you can do, but this is a top of the line Samsung fridge. Twin compressors, Double doors at the top and two drawers at the bottom and huge, so it might be worth taking a whack at cleaning it.
I have been reading on the Internet and they talk about vinegar and baking soda. I think we are past that. Any suggestions? Any magic available?
Re: OT Get odor out of Fridge?????
First
TSP and Chlorox.
Take the shelves and drawers out and put'em in a tub with warm water, TSP, and bleach, and soak them for 24-36 hours.
Remove the filters and discard. Get new.
Scrub the walls with a scotch-brit pad/sponge and more TSP and bleach, then rinse.
Scrub the drawers and shelves and rinse.
Reinstall the shelves and spread a full box of Arm & Hammer on 2 trays, put in the box and freezer then close up for 48 hours without running the cold.
If that doesn't work, you're on your own :(
Jim Dillon
Barry, your problem brought a smile and old memories to me. In the mid-1950s my parents bought a new chest-style freezer and filled it with 500 pounds of packaged beef. Summer time. Went on vacation but, as we always did, pulled all the electrical plugs. I was very, very good at my assigned job. Came back two weeks later and wondered what that smell was. Couldn't figure it out then we opened the freezer. The horror, the horror, the ... . The local garbage man wouldn't even take it - would kill his hogs he said. After cleaning with vinegar, bleach etc., plain old baking soda was the only thing that got rid of the remaining smell. Mark's plan sounds like a good one and the Samsung appliance should be worth saving as they are expensive. Jim
PS Don't forget the gaskets. I vaguely remember the gaskets retained a lot of the remaining smell.
I've adressed this before on this forum......
Tim Greif - West of Chicago
As long as your odor is organic, any good oxidizer will be your friend. I bought an ozone generator for my river house a couple years ago to successfully eliminate some musty odors. Ozone is a very strong oxidizer. So is bleach.
A year or so ago, I suffered a power failure that went unnoticed for about a week and a half. Two refrigerators with food left to spoil. Main fridge had the most stuff. Second fridge had a lot of frozen meat - beef and chicken plus frozen pizzas. I already had that small ozone generator that I successfully used to eliminate some objectionable odors in the place. I was very skeptical that it would eliminate the fridge stink. I set it up on a box and let it blow ozone directly into the fridge with the door partially open for a few days.
I was pleasantly surprised. The worst smell was the second fridge which had the spoiled beef and chicken. That one had absolutely no residual odor after treatment. The main fridge had no residual rotten food odor, but we have never been able to get rid of the faint smell of vanilla from the ice cream that was in the freezer section. I'm convinced that is a chemical smell, which I believe oxidizers have a problem with. But the organic smells (think rotting food) respond well to ozone (or any other strong oxidizer).
With the amount of places you fix and flip Barry, I'd recommend you invest in an ozone generator. You can find them on Amazon for a little under $200. I have friends and neighbors who borrow mine for everything from freshening up their basement to eliminating residual smoker smells from cars they buy.
Good luck.
Do what NASA does
Gary Smyth
"... to keep odors at bay inside the ISS ... include an activated charcoal bed, a lithium hydroxide sorbent bed, fan and oxidizer. A fan sucks odors into the charcoal, which also contains phosphoric acid to absorb ammonia. Past the fan, recirculated air is oxidized .... The air is also heated up and then cooled, while the system removes by-products."
For years at Union Carbide I sent out pounds and pounds of activated carbon to solve your problem. It is so good it is used in a fabric sandwich for chemical protection in some military uniforms.
Look up data on activated carbon. It's a open secret for your application. You require a surprisingly little amount. Air needs to move through it to work but for plain odor it can't be beat. Calgon or water purifying companies are the place to get it. You could build this as in a squirrel cage fan dust filter.
jessecloud
I remember a few decades ago, a buddy and i went to check out his father's fishing cottage on the Ca. coast. He used squid for bait and kept it in the freezer. You guessed it. The freezer had been dead for at least a month. Worst smell of my life, and there have been many.
Opened all the doors, used baking soda and vinegar on the freezer and it smelled fine the next day.
Good luck my friend!!
Re: First...Thanks Mark....
This is basically what I got on the Internet, but its good to get the reinforcement from someone I know and trust. My squeem factor is pretty low and I think this fridge is worth saving.
Thanks Jim, I will follow the advice form you and Mark, and I will be sure to address the gaskets.
Re: I've adressed this before on this forum......
I was thinking about Ozone. In fact, I rented an Ozone Generator a couple of years ago to treat a house that had had Cat lady living in it. I researched it and learned that many of the generators are crappy and don't actually generate much if any Ozone. I think the one I got was putting out very little and I got almost none and little or no effect.
A friend gave me a tiny one. Not sure how well it works I will try it. It is one you leave in a room to make it smell like a thunderstorm. I helped a guy find a house to flip. Turns out he has a carpet cleaning company and has really powerful ozone machines. I said to him I was doubtful the ones I was dealing with were doing anything. He said the ones he has will kill you. I may borrow one from him.
I may have to buy a good one. Is your experience you can easily tell it works?
Re: Do what NASA does
I almost forgot. The same friend that got the fridge got literally a ton of activated carbon at an auction in fifty pound sacks. He sold it all. BUT, he sold one sack of it to my son and about half of it is sitting in my basement. I will figure out a way to use that. Thanks. Not sure about the rest of NASA's stuff but I will keep thinking about it.
Thanks for the encouragement Jesse. I am going to give it a shot.
Be VERY careful about using....
Brian Roberts
Scotch-Brite pads or anything abrasive on it!
Even the fine abrasive pads can put fine scratches in plastic or metal surfaces.....which will ruin the looks and make the surface difficult to clean (think harboring bacteria) forever after.
Even the kitchen type pads are abrasive enough to scratch many surfaces.
Re: Be VERY careful about using....
Good thought....Thanks. I think the Scotch Brite pads actually have grit imbedded in the fibers. The white pads don't, I think.
Jason Roehl in Lafayette, IN
Many years ago, I was given a chest freezer that had been filled with venison and unplugged in a garage during the summer (in Indiana--hot and humid). My wife and I scrubbed it out with a baking soda paste after a general cleaning, but there was some lingering odor. The odor wasn't too bad, so we started to use the freezer, but we packed the remaining space with newspaper, changing it out every few weeks. After a few months, the odor was finally gone.
We replaced that freezer a few years ago with one that was 50% larger (current one is 6' long--we have 3 teens and my FIL is a beef cattle farmer), and our electric bill dropped $20/month immediately.
Jason
check out the ones on Amazon in the $100-200 price range. Read the reviews as a guide. I can definitely smell the ozone on mine. You don't want to be in the place with this running. I ran mine on "Hold" which means continuously. Showing up at the place was an exercise in holding your breath to go in and turn it off and open windows and doors to air the place out.
I heard about ozone years ago when the town we live in had a lot of flooding. Lots of folks got wet basements and had to rip out drywall and insulation. Nalco Chemical Co donated the use of trailer mounted commercial ozone generators to pump ozone into a bunch of homes (non-occupied, of course). It completely eliminated the dank musty smells from the flooding. I'm a believer.
White pads contain aluminum silicate
Dick Coers
according to 3Ms site. Sounds like abrasive to me.
Re: White pads contain aluminum silicate
Thanks again. I thought I remembered that the white ones were nylon only and did not have abrasives. In this case I will be careful and not use them. I suppose its possible there are other brands, but I'm not taking the chance.
William Duffield
The Norton Bear-Tex non-woven white pads say they are non-abrasive. I had always assumed the 3M white Scotch-Brite pads were too. Thank's for the heads-up. I've seen lots of examples of Chinese companies making knock-off products that were the same color as a higher quality U.S. product, but who'da thunk 3M would pull a trick like that?
Well...you have been warned....
Brian Roberts
3M says "Performance is similar to steel wool grade 0000".
Rub a highly polished plastic surface with any "Scotch brite" type material...or 0000 steel wool and you will see that it does leave abrasion marks behind.
An ignorant suggestion
Not by John but by who ever suggested it in the first place.
Chlorox is made by dissolving chlorine gas in sodium hydroxide. Add an acid, vinegar, and the chlorine gas will come undissolved. Why releasing chlorine gas from the solution would be beneficial to cleaning, or the cleaner, is a mystery to me.
Scrubber/sponges
we have are labeled "Non-abrasive". They are not actual Scotch-brite. I was using the brand name as an example.
When in doubt, just use a sponge.
Alexander Grigoriev
Use blue non-abrasive scotch pads. They really don't scratch.
Re: An ignorant suggestion
William Duffield
The American Society for Microbiology says.
The reasoning is explained in the article:
"At alkaline pH values of about 8.5 or higher, more than 90 percent of the bleach is in the form of the chlorite ion (OCl-), which is relatively ineffective antimicrobially. At acidic pH values of about 6.8 or lower, more than 80 percent of the bleach is in the form of hypochlorite (HOCl). HOCl is about 80 to 200 times more antimicrobial than OCl-."
As John notes, it is important to add the acetic acid last, and just when you are ready to use it. From the date on the article, soon after Dr. Bruce Ivins was identified by the FBI as the attacker, it was written to offer advise to those who may be subjected to a terrorist attack via the postal service with weaponized anthrax spores.
