Performax 90243 Air Filtration Unit
CharlieL
Today I got a deal on a new in an unopened box older version Performax 90243 from a private owner locally online. It has three speeds, 300, 350, and 400 CFM, with remote. I plan to use it in a small basement shop thats about 10 ft X 10 ft. Just curious if anyone else has this unit and what their thoughts are.
Re: Performax 90243 Air Filtration Unit
CharlieL
I did some searching for filters for this unit, and it looks to me like Rikon, Powertec, and Wen make similar Air Filtration Units. Wen having the best deal on a 2 pack of outer filters.
CharlieL
I noticed that Grizzly also sells a similar unit ( another source for filters I'm thinking ). Yesterday I looked over the Performax box a little more, and the label on the box has a date of 2010.
CharlieL
In the basement small shop it has a suspended ceiling. I was thinking about mounting it to the ceiling in the center of the room, but that has it's challenges. To do it right I feel that I should hang it off of the ceiling joists, and add a electrical outlet in the joists as well. Instead I may just sit it ontop of some shelving thats along the wall where there is already an electrical outlet and be done with it. I haven't decided yet which to do.
Re: Performax 90243 Air Filtration Unit tweek
CharlieL
This morning I opened the box, looked it over, plunged it in and it works good. It seems like a nice mild airflow for a small shop. I then shut it off and pulled the filters out of it to inspect everything else. What I found is a wire screen that was forced into the machines opening because it was cut too large, so it was wavy distorted and up against the squirrel cage blower. So I pulled it out, trimmed it a bit to fit correctly, flattened the screen out, reinstalled it, and screwed it back in with a added washer to each screw. Now the screen should never vibrate on the squirrel cage, or anything else inside. Plus the screen now looks like it should have.
Sounds like you're off and running
BTW, I vote for the outlet at the ceiling.
Re: Actually this is the hardest part
CharlieL
Ellis, I agree that it would be best to mount it to the ceiling and be able to have more choices on where to mount it, such as the center of the room, or offset, etc. But with that there are some challenges in my situation. The room is small and I have several things in the ceiling to work around, A recessed ceiling by a window along one wall. A 2' X 4' four bulb fluorescent light fixture recessed into the center of the ceiling, and a boxed in ductwork hanging below the ceiling. In the manual it says to keep the unit atleast 3 ft away from any heat registers, there is one close to where I'd like to put the unit. And then there is a head room issue, as it is now the suspended ceiling is at about 7 ft 2 inches with really not much room to go up with it and still be able to manipulate ceiling panels, the unit with hooks is about 1 ft tall, and I'm about 6' 2". So I have been thinking about all this for a bit, and need to think about it a little more so I have the best outcome without having to redo it several times before I'm happy with it.
William Duffield
The most important consideration is to capture the most dust quickly by the filters, before is settles out of the air or is captured in your lungs. This requires the largest volume and smoothest air flow through the unit that you can manage. Think of all the NASCAR road and track races you've ever watched. Where were the cars moving the fastest? On oval tracks at the start-finish line and in the back straightaway between turns two and three. You want your filter at one of those two locations and moving air in the direction of traffic You don't want it in the infield, or in one of the turns, or way up in the stands, or at the entrance or exit to pit row. To decide which location and which direction the filter should be pointing, consider where you are going to be generating the most and finest (and therefore most harmful) dust. Wherever that is should be in front of and below the intake to the filter so you capture as much of it as soon as possible.
Joseph Mulherin
Your explanation of using NASCAR was very good and correct. However, in my case I will have to put it between a couple rafters at the 1 to 2 turns and still get good airflow. My unit has 4 speeds and CFM is greater as the higher setting is enacted.
William Duffield
Yeah, once you understand the concept, it's a lot easier to find a place, even if suboptimum, that still provides good, laminar air flow that circulates as much of the air in the shop as possible. Sometimes, for example in an L-shaped shop, you might need to use two filters to get effective cleaning.
Make It Easy
Put your unit nearer one wall and then mount a small fan near the opposite wall blowing in the opposite direction. You'll get a near-perfect circular flow around the space. A little 8" HVAC duct fan wired into the filter box's circuit is all you need.
Re: The intake direction is a good point
CharlieL
And I had considered that also. What I was leaning towards was the opposite of what you guys are saying, only because I did not want to put the exhaust side towards a door opening leading to another room. But I suppose that I could turn it 90 degrees and the intake would be closer to the dust producers. One other concern that I have is, can I mount a electrical receptical above a suspended ceiling ? or do I have to mount it where it can be seen ? I also need to check and see what the wire situation in the light fixture and the wall switch to see where the power is coming in and decide if it's doable, or if I need to find a different source. As far as mounting the unit to the joists, I think that I'm going to skip the hooks and chains, and go with a piece of angle iron mounted under the joists with holes for redi rod to screw into the unit, and double nut on top of the angle iron. Then I can adjust the level of the filtration unit under the suspended ceiling. I hope that metric redi rod isn't hard to find, and not too outrageously priced.
Re: Found the metric threaded rod
CharlieL
My local Fastenal had what I needed, 6mm threaded rod, and some flange nuts, all at reasonable prices.
Re: Drop Ceiling Grid Switch Box Mounting Bracket
CharlieL
I'm thinking that this is the way to go, and corner mount it. http://www.garvinindustries.com/electrical-junction-boxes/switch-boxes/drop-ceiling-bracket/dcb
Re: Performax 90243 Air Filtration Unit install
CharlieL
Last night I mounted the brackets and the drop rods to the ceiling joists. Then I did a little head scratching as to how I'm going to bring the rods through the suspended ceiling in the easiest way, and in a way that looks good. I think that I have it figured out, and hopefully I'll be working on it some today.
