Variations on Pull-Out Table (Kind of Long)
Alan Young
I have been working on a design for an expandable table. I admit I have never seen up close the under workings of the Tage Frid design-
which doesn't seem to have been a new idea-Google searches showed many tavern tables and older styles that seem to function this way-ie the Ends sit underneath the top when collapsed but pull out for extension.
After quite a few searches and You-tube viewings, I think I found the basic way this table functions:
Lift the center section and pull out the end slide.
Repeat for the opposite end.
Each extension mounted to a pair of tapered slides.
The Tapered slides run through the grooves on the end apron and underneath the cleat screwed to the top of the long axis aprons.
My proposed alternative design has the end aprons pulling out with individual leaves stored in a cavity under the top. When closed it looks like this:
Here is the closed end apron.
Here the apron is pulled out revealing an apron that is connected to the slides via reverse groove-matched aluminum bars.
The outer piece is removed so the extended apron edges don't interfere with a person's knees.
The table extensions are removed from the underside cavity.
The end caps from each apron extension are stored in the underside cavity
The table with extensions open and end caps stored.
What are the advantages to this revised idea?--I haven't used the original design so maybe I'm inventing problems that don't exist.
1. It seems with repeated use the extensions could have their finish marred by the sliding in and out process- In my new design the leafs can be stored with a padding around them to prevent marring.
2. In observing you tube videos every one that operated the original design was a moderate to large sized male- ie a person who could reach across the width of the table-lift the top then slide out the extension. My potential clients include a female who is not large at all in stature so my design allows for an easy method to pull out the end apron, set it aside, pull out the leaves, set them aside and replace each removable end apron in the same storage cavity-finally-place the extension leaves in place-Never needing to handle more than one item at a time.
-Alan
