saw blade adj
joe v
after a hard move, when I set my tablesaw up again, it was off-center.
The blade is not perpendicular with any 90° angle. It's a Delta saw kind a old but still a good shot.
I just need to know what bolt or nut to turn.
joe
saw blade adj
joe v
joe
You need to give a model #
Keith Newton
The trunion hangs from the underside of the top on contractor type.
On Unisaw type, it hangs in the cabinet, and the top is held on by 4 bolts at the corners under the top. For this, you will need to loosen and adjust the top to align to the blade. I don' t have a link, but I think there is a good tutorial to guide you, probably on this site.
Re: saw blade adj
John in NM
Is the blade still parallel to the miter slots?
Joe, if you haven't found it, here is a link *LINK*
http://www.woodcentral.com/cgi-bin/readarticle.pl?dir=powertools&file=articles_111.shtml
