replace prehung door
JB
I am replacing an existing door and jamb. I want to replace with prehung. The door will need to be fitted to the inside flooring material (carpet), because it swings in. The existing door is 79", so it's been cut to accommodate carpet. When I removed the existing jamb, I see that it goes a SOLID inch below the existing finished tile on the outside of the door. The surface below seems to be either a glue or rubber material. What do you suggest? Should I fill in the gap with something? If so what? I was thinking of concrete, but I'm not sure if it will work because of the glue or rubber below? Should I purchase the prehung and extend the jamb at the bottom? If so, how?
The door manufacturer states that the door can't be undercut more than 1" max. It's a solid core door.
