The Floating Credenza - Hikido (door building)
Brian Holcombe
Good morning! The cabinets I have been building are moving along at a very fast past. In order to make last weeks submission date for 'Works in Wood 2016' I put in a great deal of effort in bringing the cherry cabinet to life. Please check out my progress;
https://brianholcombewoodworker.com/2016/10/11/the-floating-credenza-hikido/
Cheers
Brian
Re: The Floating Credenza - Hikido (door building)
Thanks for the update. Nice to see your craftsmanship in action. That will certainly be a terrific piece when completed.
Gradually more and more Japanese tools are finding their way into my workshop and almost daily use. I am gaining a real appreciation for them.
Thanks for sharing!
T.
Excellent blog post as usual, Brian. Your work methods are very inspiring and the documentation is superb. I look forward to visiting the Works in Wood show next month to see your work in person.
Brian Holcombe
Thanks Thomas!
They're hard to resist.
Brian Holcombe
Thanks Ellis! Excellent, looking forward to meeting you as well. Should I be accepted I will likely be there on the opening day.
Did you get a chance to stop by the Wharton Esherick exhibit? That event was a lot of fun.
Floating (dupliate post to blog)
Gary Smyth
Brian,
As a floating cabinet I presume that you mean that it will have no underneath supporting structure. How do you propose to hang the unit? You did not appear to make effort to reduce the weight, or be overly concerned with load, balance, or center of gravity. Is there something other than a French cleat to enable the cabinet to float? Custom hardware? Where are the attachment points?
Looks great. Hope you do well with the competition
Re: Floating (dupliate post to blog)
Brian Holcombe
One step at a time :D
In addition to my comments on the blog, I have determined that I will keep the walnut cabinet as a wall-hanging unit and make the cherry cabinet 'floating' in a more abstract sense. I'm concerned that a requirement of attaching cabinets to their walls might be reason to reject my design from a potential gallery.
So I will have an example with the stand, and one without.
FWIW, I went and stood on the cabinet in my study, while I'm not the most extreme test (and dont want to be, hah) it held my weight in addition to all the media components without budging.
Is the wall straight for the required distance
A bow in the wall, not unusual, would make attachment a problem.
Re: Is the wall straight for the required distance
Brian Holcombe
You can shim the cleat.
William Duffield
Since there is one credenza and we already know it is straight, but the potential for many walls over its lifetime, it would make sense to shim the half of the cleat attached to the wall to straighten it to match the half of the cleat permanently attached to the credenza.
Brian Holcombe
Exactly, that is what I plan to do.
William Duffield
I figured you knew that. The comment was more for the general readership, just in case someone following along was jumping into a similar project and had assumed that the shape of the wall was somehow cast in stone. :D
I have another thought: If you design the "legs" for the competition piece as a pair of massive "L"s tied together with a pair of beams with a cleat attached to the upper beam, then the credenza could be lifted off the legs and hung on a wall at any time in the future.
Brian Holcombe
That's funny that you mention it, I have been seriously debating installing the cleat on this credenza.
My hangup with that is that modern credenzas are often used as room dividers, so the back has to look nice. While the cleat can look plenty appealing, it will stick out 1/8"~ from the back to create a reveal...which is not so appealing.
I've built the base already, :D Even with the flu I can't seem to avoid spending most of my day in the workshop, hah.
Good point about on-lookers.
inspirational!
Joseph Piotrowski
that is art!
Re: inspirational!
Brian Holcombe
Thank you Joe!
