How to install new urethane tires on a bandsaw...
Joe Pack
Step #1 - Buy 1 quart of rot-gut whiskey.
Step #2 - Drink rot-gut whiskey.
Step #3 - Repeat steps #1 and #2 until urge to install the &^%%$$%^&^%$%^& things disappears!
Re: How to install new urethane tires on a bandsaw...
alternative way
get the tire started on wheel. clamp that part in the wood vise to keep it in place. Proceed to finish the rest by working tire up each side of the wheel.
at least this approach worked on my Delta 20"
Re: alternative way
Keith Newton
Not on a large one. The recommended way is to to clamp it to the bottom, then stretch it to the top and clamp the other end. Then you can stretch the halves like drawing a archery bow.
Follow that by inserting a rod or dowel in between wheel and tire, then roll it around a couple of times to equalize the stretch.
Dick Coers
A friend of mine created a fixture that works like a charm. Cut a plywood disc the diameter of the wheel. Cut some tapered pieces of wood and screw them from the backside onto the disc. Clamp the disc onto the wheel. Start the tire over the ends of the tapered blocks and work it up the taper onto the wheel. It's a nice even stretch, very easily done.
paul in AZ
I recently fought this battle. Used an orange tire [can't remember the brand].
What finally worked quite well after much frustration and cussing was to put the new tire into a bucket of hot water, let it get good and warm and stretchable. It had been recommended that I boil the tire but I was leery of that.
Clamp one point and work it on. I had to take the lower wheel off to make this easier.
bob murphy
I recently installed the orange style tires on my BS. Before starting, I unwrapped the tires and put them on the hood of my pu truck for approx. 3 hours. They stretched over the wheels very easily.
Installed
Joe Pack
I tried. Then I watched the videos on YouTube. Then I got hot water. Then I tried again. I clamped. I stretched. Then back into the hot water. Finally, after gouging my hands arms and belly (had to have a 3rd hand to hold a long screwdriver), I said "P%$$ On It!" and regressed back to my childhood and bicycle tires. Clamp the sucker to the wheel, tie down the wheel, grab 3 round shaft screwdrivers, used a bit of soapy water for lube and go roundy-roundy the wheel until the sucker pops on. Done.
I actually don't drink, but, if I ever install another set of these things, I might start. :-)
Ron Pemberton
What make and model of a pickup? Yuck yuck.
Re: Installed
jerry roberts
You know, I tried all that stuff a few months ago with my18 in. Jet. Everything I tried was a pita. Went to google, I think,put belts in a pan of boiling water for a couple minutes and each belt took about 10 minutes. No problems since. They slipped on with no effort at all.
Re: Installed
jerry roberts
should have said tires.
tool for the job came's with tire or should
del schisler
the place i got my orange tires , came with a screw driver and and a sleve that was on the driver so that you started the wheel we say at the top and than take the tool and go around the tire and it went right on no trouble or fighting it also use hot water first , you should have got instruction's with the tire ??
