A good find.....
A good find.....
A good find.....
Been posting about making beds for my grand daughters and agonizing over how to connect the posts to the rails. Just went to Fastenall and found some square nuts. These are not the classic ones. These are about 1 3/16" square with a threaded hole in the center. The are just under 3/8" thick. This will make it simple to chop a mortise for them and insert the bolt through the post. They are big enough to provide plenty of surface area and not rotate when captured in the mortise. I think I am going to like them.
Re: A good find.....
Might want to check out LV's knock Down Fasteners'
Charlie belden
Round holes are easier to make than square holes.
It's easy to push the 'barrel nut' too far into the hole ~and/or with the threaded hole out of alignment. Some bees wax on a small dowel will let you move and rotate if necessary.
Re: Might want to check out LV's knock Down Fasten
See my post down below on barrel bolts. Saw some on the internet that looked interesting. The "nut" was shaped like a crescent moon or half moon about 1 1/4" in diameter. You drilled a 1 1/4" hole in the rails and then an endgrain hole through the end and through the post. I liked the look, but was not sure they could be replaced if they go lost. I going with a captive nut and an ordinary bolt that should be easy to replace if lost. Thinking about a permanent pouch for parts and wrench during the moves.
Re: Might
be good to reconsider the "1/2 moon" nuts whose curved face mates with the side of the hole. They spread the stress on the wood over the curved surface of the hole and are much less likely to dig in (and loosen up over time) and/or generate a split between the rail hole and the end when the bolts are tightened. You can make them mostly loss-less by gluing a couple of small blocks in the hole as retainers.
Don't overthink this Barry.
Tim Greif - West of Chicago
Old drafting tables have been held together for many years with rail to post hardware that was no more than 5/16-18 bolts with normal square nuts. Simply bore a 1" diameter flat bottom hole partway through the rail at the bolt hole location with a forstner bit. The flat nut gets captured very nicely in the hole and is easy to hold in place with your finger as you start the bolt. The nuts shown are only 9/16" across the flats.
Fooey....That takes the fun out of this....
I just glad I can still think, let alone over think.
My son once told me, "I'm not even going to TRY to help you because you are going to do it the hardest way possible anyway." Apparently, he knows his father well.
"When I think back on all the crap I learned in highschool, it's a wonder I can think at all." Paul Simon.
I'm committed now, I have nearly $11 sunk in this.
Joseph Mulherin
Barry, awhile ago you asked if it was possible to re-air the rattle cans if they seem empty and still have solutions inside....well, Chris Fix has a video on YouTube which shows exactly how to do it with the air compressor tire refilling nozzles. and you can vary the pressures inside depending on the manufacturers of the individual cans for protection from exploding from too much pressure.
