Web photo to life size image
Gary Smyth
Earlier post regarding a table leg led to this post. I want to take a web photo and turn it into a accurate life size image to be placed on canvas.
In earlier days this could be done several ways.
1. Using proportional calipers a grid could be placed on the original image and the lines marked proportionally on a larger grid on the canvas matching the line as closely as possible.
2. A film transparency slide could be made of the picture and projected onto the canvas and then drawn following the image. Depending on on the original image, film grain, and the projector it worked, but with distance the lines became fuzzy and less than ideal for reproduction. The copy person's shadow also became a problem as the pencil approached the canvas.
3. A person with artistic talent and time could reproduce it from scratch. On several levels, not an option for me.
The question/problem is this. The web photo is approximately 2"x 3". I need to make it five feet in height on the canvas. Is there some way that an computer enhanced digital image can be produced and generate an acceptable image without exploding pixels into an unrecognizable checkerboard? Who can do such a thing? Computer people? Graphics places? Printing firms? Sign/billboard makers? CNC (NC) operations?
Local places look at me as if I'm more than a bit nuts (probably correct) and they haven't helped. Web search has delivered little of value. I'm looking for suggestions -- either places to check out or maybe software programs that can do the enhancements that I can take to a giant printer.
Budget is limited to $100 or less.
Re: Web photo to life size image
Mark Nowicki
If you lived in my area (West Island/Montreal) I would send you to:
mprepro.com
They charged me a $1.50 to copy a 44" x 30" blueprint.
Good news, bad news
Rod Peterson—Ormond Beach, FL
A photoeditor, such as freeware GIMP, can easily scale from any size to any size. You may have to print it in parts, but at least the image will be life size.
The bad news is, pixels are pixels and they aren't scalable. Depending on the density (dots per inch, or dpi) of the original, there are only so many available in any graphic to represent your image. The more you scale it up, the larger those pixels become. Eventually their size will render your image unusable.
Rod
TomD
What I do with all that kind of stuff is import it into CAD, and then cad over the top of it. This then allows me to do everything from scaling it any way I want, to printing it. I could run a CNC from it, it is super fabulous. If you don't do cad it probably sounds daunting, but really learning, snaps, trims, and how to make circles, lines, and bouleans (simple to do fair curves controlled by points) is all you need to know.
One fun thing you can do with laser printers is use them as heat transfers allowing super accurate pictures to be transferred to wood or metal.
This a standard process for me: Go to CAD thread.
A similar thing can be done with any software that will let you trace over a bitmap with vector graphics. Photoshop is one, Illustrator, there are others. Vector graphics can be scaled to any size without loss of resolution. Note that the actual drawing of the lines in any of these programs, including various CAD programs, will require beating the learning curve. (I made a career from CAD, 3D, and a variety of image and vector graphics. I prefer CAD.)
Note that there is software that will interpolate between pixels and create an artificially higher resolution image so when you blow it up it won't be so pixelated. The software I used a decade ago was amazing but expensive - I have no idea what is available now.
Another way is with an opaque projector, project an image from a print on a big piece of paper and trace over. Toy versions of this are very inexpensive but may work OK in a darkened room
Just what I need
Gary Smyth
" there is software that will interpolate between pixels and create an artificially higher resolution image so when you blow it up it won't be so pixelated."
Exactly what I'm looking for. What is this called? I can do a search if I know the correct terms to search. This is a one off project. If some one or place has the capability I'll reach out.
Re: Just what I need
Larry
Gary, Where are you located?
The software I had was many 100s of dollars and required a full version of Photoshop to work. Unfortunately, I can't offer to do it for you since the computer holding the software and the license quit booting about 10 years ago and I haven't bothered to even try to debug it. Funny what retirement does for you...
I searched google for 'image enlargement software" and looked at just a couple of hits. Some of these appear to be very good at moderate enlargements but they still may help with the extreme blowup you are looking for. But a lot depends on your expectations. If you are expecting an extreme enlargement that is crystal clear and razor sharp you may be disappointed. Algorithmically manufacturing data by interpolation eventually falls apart!
At one time I did careful experiments with different interpolation algorithms and the software I used was impressive, especially where the image had contrasting edges such as what you will probably have. They are not as good on images with a lot of busy detail. I wish I had my test images to show you but they are on that same computer (and somewhere on archive disks). I made extreme blowups of small test images that were still quite pixelated with the best bicubic interpolation built into Photoshop but were amazing with the special software.
However, note that just increasing the "resolution" of a bitmap image (photo) may not be the best solution past a certain size. The problems you start to run into are related to memory requirements and processing speed. On my 2005 era dual processor machine (a powerhouse at the time) my images sometimes well exceeded 500 megabytes. Today's machines with a lot more memory may be able to handle these big images better but you may still experience long waits between operations and a lot of disk paging and thrashing. I've had images that took over 10 minutes for a simple operation or even an errant mouse click in Photoshop. Took all day to get something done...
As mentioned before, using vector graphics instead of bitmap images eliminates all of this. You can trace the outlines of a 640x480 photograph and create a vector line drawing and enlarge it as much as you want with no performance issues.
you might try...
Tom Dunlap
Office Depot/Max
Costco
Have you looked for a larger copy of your image?
You're probably onto this, but Google will search the web for your image and show you all the different sizes and versions it finds, along with similar images if any. Just right-click on the image and select "Search Google for image." Who knows? This could give you a big leg up on your quest.
I'm trying to figure out whether you need a photographic rendering of the image, in full color with all complexity that you intend to mount as art, or if you just need an outline that you can templacize and use to bandsaw parts. Regardless, Illustrator is probably your friend, but it isn't cheap and I'm told it is pretty complicated to learn. Our art directors and illustrators used it all the time for magazine drawings, etc. But, as JKJ has nicely explained, vector renderings are the way to go for extreme blowups. A 2:60 blowup of a 72 dpi image will only have a couple pixels left per inch in the large image.
My advice is to befriend an illustrator and see if they can render it somehow and tile it for you.
Southwest PA near Pittsburgh
Did not know
Gary Smyth
Typically I still work with Explorer. That option is not available. Switching to Chrome it is and I can get a slightly larger "original". The search image option before this I did not know existed.
My best bet today is to take a 2 1/4 image with a traditional camera as a transparency directly off a computer screen and project it on to a canvas. In the mean time I'll check with additional ideas suggested here. Thanks to all. With additional information I may be back.
A neighbor has some ties with Carnegie Mellon in their entrepreneurial section. Much computer power and large printer there and the people who might be able to get me to the right person and importantly some crunching time at a reduced rate.
Been trying to figure this for quite a while so another month won't amount to much.
Thanks all.
Jim Dillon
Gary, Genuine Fractals was a well-known piece of software that had a good reputation for enlargements. It has now been incorporated in ON1 photography software and renamed Perfect Resize 10.5. I see it is offered as a free trial but probably has some restrictions. Qimage is another piece of software that enlarges photos but I don't know how it compares to Genuine Fractals.
Given the size of your original image, it would really depend on the resolution of the original. If it is the normal 72 ppi intended for screen viewing, then I think you are out of luck. If you have a print copy, maybe you can scan it at a high resolution, then enlarge with software. Just a thought. Jim
https://www.on1.com/products/resize10/
http://www.ddisoftware.com/qimage-u/
John thanks
Gary Smyth
Largest photo is 600 x 1000 I can locate. It will take some time to find out more. There are several images in that size and some are multi or mislabeled as to the photo title so the source search will take additional time. Until now I never heard of a vector line so that is a good lead. Thanks.
Re: Southwest PA near Pittsburgh
Larry
I have a friend who can do it but we are in California
Thanks
Gary Smyth
Through help here I found additional images. I found five and all have different sources and the several of the titles are inaccurate. I'm trying to get a source that is correct. If found, a print or larger digital may be available.
I don't believe I can purchase the software and even if I did the learning curve and time involved to do that is prohibitive. Where is Jet Propulsion Laboratory when you need them?
I'll check out your lead. Thanks
Will do.
Keep me in mind.  Checking local leads first.
Re: Thanks
William Duffield
Can you give us a link to a copy of the pic you want to vectorize and blow up?
This is the graphics application I use. I've been using it for maybe 25 years.
http://www.canvasgfx.com/en/products/canvas-draw
It will do most of what photoshop and autocad and pagemaker and paint and other very expensive packages will do, but it is not much easier to master than they are or than all the woodworking hand and power tools and drafting tools in my shop. It does not do 3D, so I use SketchUp for that.
I have an inexpensive large format printer, but it only prints up to 13"x19", so if I needed a 4'x5' drawing, I'd still need to print out several sheets and tile them together, or go to Staples or Kinkos.
Check color labs
Publications and individuals, if they don't have their own pre-press department, send their projects to what we called color labs, which will scan all kinds of originals and do what it takes to digitize, enlarge, enhance and print stuff to order. I'm not sure if you need to own the copyright for the work they do for you. There's certain to be one of these places in the nearest fair-sized town who could advise you on this. It could be worth a visit. Printing costs will vary depending on the output device and the color palette of your image. If all you need is a line drawing, they might be able to output it on a plotter and save you a lot of cost.
Since first post did just that...
Gary Smyth
and awaiting responses. One college suggested to have one of their graphic artists/student artists take their best enlargement and redo the art and then take the new rendition and enlarge that to approximately five foot vertical in several steps. The cost is reasonable and that option is a consideration, but it pretty much defeats what I want to do as I want it for my art project.
I'll see what develops in the upcoming week.
