Really, Really OT: Olive Oil
Stuart Johnson
I like to cook my eggs in spicy hot oil but it is expensive. So I make my own by grinding up a couple good handfuls of dried pepper (wearing my 3M respirator helps) and slow cooking them in a pint of olive oil. After about half an hour I strain and add the oil to a pint canning jar. This will make a regular canning pop as it cools. The resulting oil is a nice deep, clear red. After cooling I put in the refrigerator. Olive oil will normally solidify in the refrigerator but in this case the oil stays liquid and clear overnight.
The strange thing is if in the morning I take it out and gently shake the jar and put it back within a half hour it will turn an orange color and start to solidify. At about two hours it will be as hard a normal refrigerated olive oil.
What does the shaking do to cause the change?
Re: Really, Really OT: Olive Oil
Stuart, I know nothing about the chemistry involved with your recipe but simply from your description I wonder if it might be a supersaturated solution, where more of the solute is dissolved in the solvent than it would normally take at a given temperature. These solutions can often be caused to release their solute by some trigger, such as shaking.
There is also a temperature dependent phenomena called supercooling where a liquid is cooled below where it would normally change state (such as water cooled below the freezing point). Shaking the liquid can initiate instant change to solid. I suspect your oil situation would be more like the supersaturated case. But maybe it is a combination or something entirely differrent.
Again, just speculation. I am not a chemist and I have never played one on TV.
Re: Really, Really OT: Olive Oil OT question
I can't help you with the question, but I have one for you. How do you cook eggs in hot oil? Do you put a little in a pan and fry them, like sunny side up, or do you heat all the oil and deep fry them? I may have made this way too complicated.
Stuart Johnson
I add a teaspoon or so to a skillet and fry them. They do come out nice and hot so if you don't like your food too tasty you might want to cut back on the amount of hot oil and use just a bit with regular oil. Work when frying catfish as well, add a few table spoon to your normal frying oil.
Thanks, I am not a real fan of HOT, but my son is. He is growing peppers in my yard to make hot sauce. Really, really hot sauce. Scott's bonnet peppers and Ghost peppers and others. I will not be using any of it. The peppers are interesting and beautiful. I will tell him about your hot oil.
Lee Schierer in McKean, PA
I suspect that the shaking the liquid adds air bubbles to the liquid, which creates nucleation sites for the polymers to link up and create the gel.
Lee
