How to replace planer belt?
JERRY DRAPER
Anyone out there know how to replace the drive belt on a Ryobi AP 10 portable planer?
JERRY DRAPER
Re: How to replace planer belt?
William Duffield
Do you mean the belt that drives the knife head, or the chains that drive the feed rollers?
Do you have parts diagrams? They provide lots of disassembly and reassembly clues, including where the side panels are attached to the base of the machine and the tools you will need.
In either case, I think you are going to find it difficult to get any replacement parts, because Ryobi has discontinued that planer and it appears they no longer have any parts available.
JERRY DRAPER
It is the belt that drives the knife head and I do have the replacement belt.
del schisler
the ap10 parts are obsolete now here is the link that may help i used to have the ap10 long time age nice planer changeing the belt shouldnt be hard to do http://www.ereplacementparts.com/ryobi-ap10-planer-parts-c-7931_7939_32545.html
JERRY DRAPER
Very useful. Thank you.
John in NM
Just looking at the parts diagram, I don't really see a tension mechanism for tightening the belt. Presumably it is a cogged timing style belt? (flat belt with "teeth")
If you can't find a way of moving the motor towards the head so that the belt can be installed loose and then tightened, I would figure out which is most easily removed (motor or cutterhead) and do it that way. Timing belts can be damaged by twisting or walking them on to pulleys under tension, just like V belts can be.
On the other hand, they should be cheap enough that if its the easy way to go you can live with replacing the belt now and then. For one application at work we use a steel reinforced timing belt - they cost all of $6.
JERRY DRAPER
Success. Got it installed by soaking in hot water and stretching it over the pulleys.
