Wood for interior porch/patio walls?????
Tim Greif - West of Chicago
LOML has decided she wants to enclose the patio of our river house to eliminate the mosquitos and no see-ums. We are residing the whole house with Hardy products, but not the patio interior since we want to hang some artsy-fartsy and primitive stuff on the walls, and that means nails. So we're looking at wood products that will be somewhat weather resistant. The patio will be enclosed with a shed roof, and all outside walls will have EZE-Breeze window/screen panels. These panels let you have as much breeze or wind block as you want. Not weather proof like a three season room, but more protected than just a screened in porch.
I'd appreciate any recommendations regarding materials, finishes, etc. We were looking at simple cedar siding, car siding and others. I'm no good at visualizing stuff like this. I've attached a simple graphic of the patio/porch showing the house in black and the patio walls and EZE-Breeze screen in red. All areas inside the patio walls will be whatever material we settle on. All exterior material will be Hardy board and LP Smartside products. There's not that much wall surface to cover since the most of entire back wall of the patio is floor to 7-foot high windows (four panels, two of which open onto the patio).
Re: Wood for interior porch/patio walls?????
Keith Newton
I think I would use Western Red Cedar, then match the lap pattern of the Hardy. My lumber supplier sells it rough on one face, and smooth on the other, so you can choose.
Because it has good resistance to decay, and dries pretty quickly, it is sold green, and pretty full of water, so will shrink a little when it dries, but not so much as to show up for this purpose.
You could leave it raw, or use a stain to get a special look.
don stephan
Will lap siding be acceptable background for the items that will be displayed? Do you want a painted background, a wood stain background, or some other type of finish?
Gary Smyth
For a generally less expensive wall covering look into T111 or wall and/or ceiling beadboard panels. Call images up on any browser. They can be placed vertical or horizontal and for a river site and under cover can serve for years. They will also work as a background for artwork. The panels are thin so if heavy stuff is to be hung, back then up with appropriate material. Both should be primed on both sides and painted as you see fit.
Clint Searl
Cypress
