A55 Smoothing Plane
Marble Table done
Marble Table done
Marble Table done
those are fossils in the top. One thing about spraying conversion varnish. Its done in minutes and the second and final coat can go in an hour later and DONE!
Re: Marble Table done
Very nicely done! I'm sure the customer will be thrilled.
Adam of Oakland
Adam of Oakland
i really like the subtle tension/springiness of these legs with the curve on the inboard side. nice project
William Duffield
As I speculated in the earlier thread, with the addition of the massive marble top, the legs do not appear too heavy. You explained very well your process for cutting them out and getting them all the same size and shape, but nothing of the design process you used for developing the curves and laying them out on the stock. Any secrets you would like to reveal?
William Duffield
Orthoceras?
https://en.wikipedia.org/wiki/Orthoceras
It didn't involve an Orthoceras-the process
I can't sketch, but I can draft. I could picture in my mind what I wanted the leg to look like but I could not sketch it on paper. But I have an array of French curves and flexible splines so I just started drafting 1:1 scale shapes on paper until I got something I thought right.
Next I made the table with rectangular prism legs and dry fit it together. I held the proposed pattern up against the leg and pictured what it would look like after I sawed the profile. I thought the shaped leg to be too dainty. Wife agreed. So I redrafted a leg 1/16" wider at the bottom, make a template, held it up and still too dainty. Repeat until it looks right.
What looked good to me, by dumb luck trial and error, was a leg that was straight for about 1/4 the distance up from the bottom and then an arc to the top.
Re: It Worked!
William Duffield
I do it that way part of the time. Alternately, I use a graphics application with Bezier curves. I just push the anchor points around until I think it looks good, and then print it out and use 3M 77 to stick it to a piece of thin plywood or cardboard, cut it out on the bandsaw or scrollsaw, and refine and smooth it with a spindle sander or rasp. The problem with this approach is I can't easily transfer the refined shape back to the computer to e-mail it to someone else.
Re: couldn't you scan the result
William Duffield
It might work, depending on the scanner you have and the thickness of your pattern. You could always trace the pattern back onto a piece of flexible paper and scan that. If your leg is longer than your scanner bed, you could draw alignment reticles on the original and piece multiple pages back together with magic tape. Since I don't much enjoy doing that, I bought a large format inkjet printer so I would have less piecing to do. It will print 13x19 paper edge to edge and top to bottom. It is a Canon iX6820.
Another option is to photograph the pattern and import that into your graphics application. Usually, though, this requires fiddling with the scaling, often different horizontally and vertically. You also have to deal with lens distortions.
Since most of us here are building custom furniture in very small numbers, we don't have to worry about getting the next one exactly the same as the last one, as long as they turn out fair and well proportioned. The other thing that saves us is that no one can look at all four (or more) legs from exactly the same direction or even under the same lighting conditions, so many small differences won't be noticed.
Not the same thing, but. ...
AZ in Colorado Springs
I once made a doll cradle and didn't feel like recording the final dimensions and angles. So I dismantled it and took it to Kinko's. They have a large copier so I had them photocopy one side, one end, one of the legs/ feet for the stand and the stretcher that connected the ends of the stand. So, I have a full sized set of "plans.". (The guy at Kinko's thought I was nuts.)
In another instance, my son wanted a drill rifle to practice with (he was in civil air patrol). No problem, we'll make one from a 2x6. We got a photo of the right rifle and again went to Kinko's and had them enlarge it to the needed length. The rest of it was in the right proportion.
Web photo to life size image
Gary Smyth
Earlier post regarding a table leg led to this post. I want to take a web photo and turn it into a accurate life size image to be placed on canvas.
In earlier days this could be done several ways.
1. Using proportional calipers a grid could be placed on the original image and the lines marked proportionally on a larger grid on the canvas matching the line as closely as possible.
2. A film transparency slide could be made of the picture and projected onto the canvas and then drawn following the image. Depending on on the original image, film grain, and the projector it worked, but with distance the lines became fuzzy and less than ideal for reproduction. The copy person's shadow also became a problem as the pencil approached the canvas.
3. A person with artistic talent and time could reproduce it from scratch. On several levels, not an option for me.
The question/problem is this. The web photo is approximately 2"x 3". I need to make it five feet in height on the canvas. Is there some way that an computer enhanced digital image can be produced and generate an acceptable image without exploding pixels into an unrecognizable checkerboard? Who can do such a thing? Computer people? Graphics places? Printing firms? Sign/billboard makers? CNC (NC) operations?
Local places look at me as if I'm more than a bit nuts (probably correct) and they haven't helped. Web search has delivered little of value. I'm looking for suggestions -- either places to check out or maybe software programs that can do the enhancements that I can take to a giant printer.
Budget is limited to $100 or less.
