Spraying things with legs
The problem to avoid is overspray from the legs in the foreground can stick to legs in the background. Here is what I do, and it may not be best. Would like to here from the other sprayers.
The foreground legs make a "U". As quickly as I can, I spray the inside of the U, then the outward facing face of this U, rotate the structure on the lazy susan 90 degrees and repeat for the 4 U's. If that works I go with it.
If I am getting overspray roughness on the inside of the legs then I do something different that is a bit more awkward. I spray all the outward facing surfaces. The I reach through the legs in the foreground and spray the remaining inside surfaces of the back legs. This orientation directs the overspray past any previously sprayed surfaces.
What do you all do?
