Appearance in edge gluing panels
Light reflecting off end grain differs from light reflecting from flat grain (think light trap if you are into optics). Suppose we have a board where the grain is not parallel to the board surface, as illustrated by this representation
where the forward slashes are grain orientation along the board edge. When viewed from the right we see light reflected from end grain and flat grain. When viewed from the left we see only flat grain. The appearance, mainly the brightness of the reflected light, will appear different depending on what end the board is viewed from.
We see grain more or less standing on end around knots, in crotches and in curly wood. It is this difference in reflection off the different grain orientations that makes these features stand out and they stand out different depending on the viewing angle.
Suppose we have grain on the edge of two sequentially sawed or sliced boards or veneer oriented /////////. In book matching we flip adjacent pieces with the result that the grain in one piece is ///// and the adjacent piece is \\\\\\. When the assembled pieces are viewed from the end one side will show end grain and the other will not, and visa versa for viewing from the other end. The result will be a discontinuity of brightness at the edge joint when viewed from some angles, for better or worse, depending on your taste. Personally it is a factor that doesn't concern me, which may be a minority view of things.
An alternative to book matching is to edge joint the adjacent pieces so that //// aligns with //// of the mating piece. In practice it becomes a compromise as to which choice looks better in the application at hand for there is an even more apparent appearance consideration .
While these appearance differences with observation angle are significant with what we call figured woods the effect disappears with boards sawed largely parallel to the grain. If the grain of a board lies parallel to the surface the appearance of the surface will be identical when viewed from any orientation. A board whose grain is ====== can be edge joined to another board with grain
====== and there will be no brightness difference observed at the joint.
In edge joining there is an effect more apparent than brightness differences at an edge and that is growth ring mating. In rift cut where the dark lines of the growth rings are largely parallel to the length of the board it is easy to get a nearly invisible joint when rift cut is joined to rift cut. The result is lllllllllllllll. But in flat sawed lumber we can get grain that looks like ((((((( or )))))) when viewed from the face of the board or combinations as we move down the length.
If the grain at an edge is joined to the adjacent board to make a pattern (((.))) where the period is the joint, the effect can be attractive. Grain ///.\\\\ can also be attractive, as well as llll.llll. Most consider other combinations to clash, for example llll.)))) and we try to avoid this combination.
In summary, when edge gluing we need to consider the potential brightness difference that could result at the joint, as well as the attractiveness of the grain match and reach a compromise that suits the builder and customer. Book matching, not book matching and "knife hinge folding" are routes to compromise.
