Does dehumidification kiln wood count as air dried
Stephen F Roth
I want to use some ash for steam bending. I understand that I should use air dried wood. A local retailer uses a dehumidification kiln. Would this wood work?
Based on some research, I understand that you should steam bend wood before it gets fully dry. My thought is that while the water content of the dehimidification kiln dried wood may thus be a bit lower than ideal, the wood has not been heated to a level to "set" the lignin, and thus may still work.
Any thoughts? I am thinking not to chance it and just get some air dried ash, which might end up being cheaper anyway.
Re: Does dehumidification kiln wood count as air dried
I thought the problem was the heat of the kiln was the problem. The heat SET the lignun. That is a very vague recollection and unreliable. You should get a better answer.
try it
I think before you dismiss this wood based on speculation you should try it for your purposes. It is not correct that KD wood can not be steam bent. There may be some differences between this wood and air dried, what ever that actually means, but these differences may not affect your application. I know a chair maker that only uses KD wood for the bent legs and backs of his chairs, because KD wood is what he can most readily obtain.
dehumidification kiln doesn't mean cold dyring
After the air from the kiln is passed over the condenser coils this same air then passes through a heat exchanger heated by the exhaust from the compressor. The final temperature in these kilns can be about the same as a steam heated kiln, about 160 F. I know the one that runs near me is hot at the end of the cycle.
The efficiency of these kilns comes from the fact that the kiln air is recycled and the energy of dehumidification is added back to this air after the water is taken out. I suspect that the main energy loss of these systems is in running the fans, something that must be done in a steam heated kiln too.
Keith Newton
You can get a better reply if you give more details, like how thick, and radius of bend. A thick member may check internally due to too much compression on the surface as the outside getting wet expands. I have gotten good bends with 3/4" thick dry wood, which started at 12%, and ended up at 18% MC after steaming, but it stayed that thickness. However something thicker parts that might need some shaping or carving after the bend might reveal the internal checks farther into the project.
Be sure to use end compression straps.
Bill's right
Dick Coers
That last heat cycle is there to sterilize the wood to kill insects, and larvae.
To try to be a bit more clear, *LINK*
Keith Newton
If it is given that any dryer wood spending an hour in a steam chamber will end up with around 18 % moisture content. Thus, KD wood starting out, will gain 12% creating internal stress, as the outside starts gaining moisture and starting to swell. If the compression properties are greater than the tensile strength, and most wood species do have higher compression than tensile properties, then it will split internally. For this reason, starting with material which has 18% in the beginning doesn't suffer those stresses.
If this is your first attempt at steam bending, I would suggest you go to the link and follow it as closely as you can. You may be able to get away with skipping something on a slight bend, but count on luck if your pushing the limits.
http://www.leevalley.com/en/html/05F1501ie.pdf
a more fundamental reason
lumber dries faster hot than cold. The waste heat from the compressor will always be put to good use to hasten drying.
Thanks for everyone's help.  Ill give it a try.
I thought a dehumidification ran cooler
Dick Coers
except for that last heat sterilization cycle.
Re: I thought a dehumidification ran cooler
perhaps somewhat cooler but not cool. In practice it is not economic to run a dehumidification kiln and not recover the heat from the compressor. In my limited experience they tend to start off cooler then they wind up hot. It is not bug driven but rather the details of heat recovery from the compressor, air flow, etc.
In any case every well managed kiln is run to remove some target amount of water from the wood each day. It takes heat to achieve targets as the moisture content of the lumber drops.
