The Floating Credenza - Build Thread
Brian Holcombe
Good morning! I've started off a new build, creating a pair of wall hanging credenzas, one for media (TV) and the other for general storage. Both will featuring sliding doors, one will featuring drawers in addition to those sliding doors.
Please check out my post here;
https://brianholcombewoodworker.com/2016/09/26/the-floating-credenza/
I look forward to your comments.
Re: The Floating Credenza - Build Thread
wood selection for panels
It is common to need to join boards to make a panel wide enough for the need. There are various ways to achieve the width needed. For the benefit of those following this build I would like to offer an alternative to what you did.
Rarely do we have available a sequence of boards sawed from a log. In the case where sequenced lumber is available book matching adjacent boards leads to what most consider an attractive result. Panels assembled from sequential veneers are invariably assembled this way because most find the result pleasing.
More commonly we have available boards unrelated to one another by close parentage. In this case I usually assemble case sides, or tops, for a single board. What I do may have a name but I don't know it. I'll call it fold back, or knife hinging.
A wide board like we might choose for a case side will be rift grain on the edges. Rift grain edges match in straight lines or vees with out clashing as shown in the pictures of case sides.
I select a perspective board and with chalk mark the lengths I need to make the side. Then I imagine what the joined edge will look like if I cut these lengths and fold one of the cuttings back to mate the edge of the other as if closing an extended knife hinge. Ideally the result will be a joint of two rift grain edges where the rift grain will make some sort of attractive mating. I diddle with where the cuts will be made to achieve the most attractive result. Sometimes the board at hand simply does not achieve an attractive result and I move on to another candidate. In the end I find this technique related to book matching achieves case sides and tops that are attractive and the color match will be perfect.
The reason why I did not book match
Brian Holcombe
...Primarily is that the grain is going in opposite directions and so while it does add to the length of time required to the plane the boards it is mostly a visual issue where one side will be dark where the other is light.
I find it less appealing as I go on and prefer instead to move away from the effect.
What I would hope to do, all things considered is acquire lumber which is wide enough to be the entire case on its own without the need to join up additional boards, but I find this as a decent compromise.
Comments
The light-dark effect you wish to avoid is only apparent when the grain is not largely parallel to the face of the board, for example in crotch wood or perhaps wood sawed near the butt swell from the base of the tree. As illustrated in the pictures, I have not seen this light- dark effect in any of the panels I have make by "knife-hinge" folding of a single board which results in a pleasing symmetry about the joint.
Re: Comments
Brian Holcombe
Thanks Bill. The light dark effect seems to allows appear to when I book match. In either case, I used this method on the Butler's desk and prefer it as it better represents the effect I'm interested in producing.
