A table is underway
Years ago I bought a Moroccan marble table top with fossils in it. Finally have gotten around to turning it into a table that will go in the sunny dining room. We will set plants on it and maybe serve off it as needed. Or it will just accumulate stuff. I just made a table frame and will simply set the marble on top.
The legs are M&T into rails. I hand chopped the mortises. I finally tried band sawing the tenon cheeks and now I see why that approach is popular.
The legs were band sawed then spoke shaved smooth with the LV shave, which I like. It has nice handles. I sawed one arc, taped the cut-off back onto the leg and then sawed the remaining arc. The result is a good looking leg and three strange looking pieces of scrap.
An experienced woodworker was watching me band saw the other day and was puzzled by my technique. It works for me and I can split the pencil line if the lighting is good. I ride the back of the blade along the kerf and pivot from this point into the pencil line as I make the cut. I aim for any error to fall outside the line. If I drift from the center of the pencil line after sawing for an inch or so I back up, and again pivoting from the back of the blade against the kerf, resaw the section in error with a light shaving cut. Watching, it looks like I am periodically gong back and forth as I progress along the guide line. When done all I have to do is shave off the teeth marks.
The stain is made from 100 parts General Finishes conditioner (the solvent they use to prepare their oil stains), about 15 parts linseed oil and about 15 parts burnt umber artist oil pigment. Stain is applied with the rubber shown in the picture, and the result wiped with a clean rag. Applied this way, it took only 10 mL of stain to do the whole table and little was removed by the rag.
We colored the lime plaster on our house with pigment mixed into a whitewash of lime and water. There is about zero prep work to do, just whitewash on another coat when needed (rarely). We ended up using the stucco colorant due to cost and the area involved, but I did find that place in Tucson and filed away the info for future reference.
