Craftsman compressor list compression
Terry Alexander
I have a "many year old" craftsman 2 hp 33 gal compressor that it takes at least 20 minutes now to get to 125 psi. BIL thinks the rings are shot. I'm not that good at non- wood "stuff".
Any suggestions? I'm pretty sure I'm not the first WC person that has had this problem 😄
Thanks in advance!
Terry Alexander in west Texas.
Re: Craftsman compressor list compression
Dick Coers
Does it really have pistons? Or does it have vanes? Either can be replaced. Don't order parts until you take it apart. The cylinder may be badly scored and if so, you have a boat anchor and an spare tank. Finding a place to order parts is becoming much more of an issue these days.
Sears Parts
My experience with their parts has been it's cheaper to buy a new tool (from somebody else)
John in NM
Yes, I would guess its the rings from what little you've said. Could be bad reed valves too, but usually with those it doesn't eventually reach pressure and turn off.
If you have an oil-less, diaphragm compressor, it could be a worn out diaphragm.
Any of this is likely fixable, if you can get the parts. Even then it may not be worth the time, $$$, and trouble to do it.
Wonder if changing the oil to some sort of "high mileage" oil would produce a better seal around the rings and get you some more life and better performance? I saw motor oil for engines with over a 100,000 miles. hmm?
I'd probably run it to death and buy one on a tool auction.
ken
Barry, I just went through the same dilemma with my compressor, mine was a small 8 Gallon Campbell/Hausfeld, just like yours it would take along time to fill.
The problem with it was a bad pressure switch and a faulty check valve, when I took the pressure switch apart I noticed how crudely it was built , so I said to myself why not buy a better P.switch and replace it, the cost of the parts(pressure switch & check valve) would be only $30 or so less than a whole new compressor of the same quality.
This was a case of throwing good money at the bad so I opted for a new compressor only because a good second hand wasn't available , If yours was a vintage one that was well worth to repair it and keep it then I would say go for it but for a run of the mill Craftsman that has reached near the end of it's life, I would say let it rest in peace, spend the money on a good second hand if a new one is out of the question.
