Wont get taut after wetting?
unnormal caning
I'm in the process of making a small guitar amp/cabinet from some parts I scrounged up and a few I purchased. My intent is to use the pre-woven caining I purchased from wood craft as the speaker grill. I did this once before and it turned out great. At the time I wasn't sure how to make the caning taut after I got it stapled to the speaker baffle, so I called Wood Craft and they indicated that all I had to is wet it with a spray bottle of water and let it sit overnight. So I did, and MUCH to my surprise it was perfect. I've done the SAME application with the current caning I've mounted on the speaker baffle and I can't get it taut, it doesn't seem to want to shrink.
So, any suggestions on how to get the caning to shrink so it will become taut?
Any information is GREATLY appreciated.
Thanks!
Re: Wont get taut after wetting?
Wet it again and use hair dryer BUT...
Gary Smyth
my experience is that once wetted it won't tighten up or as much a second time, but test and it may work. Unless done evenly. it may pull the weave out of alignment.
Dick Coers
Dear Caning, you have an usual name! My guess is you didn't get it wet enough. Most instructions say to soak it for between 30 minutes to a couple of hours, until supple. Misting won't do it!
Ralph Lipeles
I've recaned many chairs. it takes more then a spray to soften/expand it. Soak it in water for 1/2 hour, then blot of the excess water and tack it in place. It should shrink nicely.
Re: Caning wont get taut after wetting?
David C. Lykins
Thanks for all the information, seems like I just need to get the caning a lot wetter than I have. So now the question is whether or not to take the caning off the baffle, or leave it on the baffle (it's plywood) and figure out a way to get it really wet with out screwing up the plywood. Looks like my best bet is to pull it off the baffle, wet it and then re-apply the caning.
Thanks again for your help,
David
Dick Coers
If you wet it in place, it will just relax and then likely just return to what you have now. It has to be installed snugly when wet so it will shrink tight.
