Have a question? Ask Woody!
Clamp pads
Clamp pads
Jack Guzman from Maine
Clamp pads
This post is about those red plastic pads that come with bessey f style clamps. I have a few of the deep jawed shorter ones that are the strongest holding clamps I own. I use them alot. The problem with them is the jaw pads fall off. I got replacements and these start to fall of after some use.
Does anyone know of a tip or trick to get these things to stay in place? Is there an adhesive that works on these?---Jack
Re: Clamp pads
E6000 to the rescue
Everyone should keep a tube of E6000 on hand. Mush some in the pad recesses, place pad on clamp and wait. ,,,,,,,I don't know anything about Bessy clamps but what I described works for all the other "F" type clamp pads.
Re: Clamp pads
Thank you
I wasn't sure if there was an adhesive that would do this. I'm going to get some of that.---Jack
Re: Clamp pads
Re: Thank you
I don't know what your clamp pads look like. In my case there is a valley in the pad that fits over the clamp end. If I fill the valley with E6000 it will squish out over the metal part and seal the pad to the metal, forever. Never had one fail on a typical "F" style clamp pad either on the bar or the screw.
E600 dries to an extraordinarily tough plastic. It is a good adhesive, but the shear on a clamp pad is huge when clamping and I doubt the adhesive will hold up by just adhesive forces. But if by one means or another the E6000 can be made to mold over the metal it will stay in place.
A fresh tube doesn't seem runny, but it is in the time it takes to set up. Consider this fact.
Re: Clamp pads
Re: E6000 to the rescue
paul in AZ
You may have started a run on that market.
I went to get some today and was told that they were sold out. "Why is this so popular?".
Then -Big orange box sold out. Lowe's had some.
Re: Clamp pads
Hobby stores
People that make jewelry use it. It seems to have replaced epoxy for some applications. In fact my wife's cousin who makes jewelry introduced me to this stuff.
Re: Clamp pads
Re: Hobby stores
paul in AZ
Bill: I got it for a couple of clamp pads but encouraged by what you said I thought to try it on gluing leather to wood.
I am about to glue some really nice suede into a jewelry box. Prior to this box I've used epoxy successfully although working time is a bit short.
Now testing a scrap of the leather onto wood to see how E6000 holds and more importantly if it bleeds through. I'll know tomorrow. Sounds like it should work.
thanks.
Re: Clamp pads
fred in ct
I picked up a good sized tube for $6 at Joanns fabrics.
Re: Clamp pads
Re: Hobby stores
William Duffield
I use E6000 for all sorts of problem gluing jobs, for example gluing Tillandsias onto sticks. My son is "into" refrigerator magnets. Based on my recommendations, he no longer has curiosities fabricated from a wide range or materials separate from the rare earth magnets that populate the front of his refrigerator. Breathing the solvents is probably not such a good idea.
Re: Clamp pads
William Duffield
It's almost ubiquitous: Lowes, Home Depot, Woodcraft, WalMart, Sears, Michaels, Amazon, Target, Blick, Grainger, etc., carry it.
Re: Clamp pads
Instead of CA?
Bill Howatt
I'd never heard of E6000 but I see it is indeed easy to find. It looks like it has some better characteristics than CA such as flexible bond but sets a bit slower.
Bill
Re: Clamp pads
Tested E6000- and impressed
paul in AZ
Tested sticking suede leather to wood. Adhesion is fantastic [although the leather lining of a jewelry box hardly calls for that]. It didn't bleed through the leather.
One minus is that it is pretty runny, a lot like the consistency of CA, so it would be easy to slop on too much.
They recommend greasing the cap's threads to prevent adhesion but I'm not convinced that this will work very well. I expect to find a cap permanently glued onto the tube next time I go to using it. Given a choice for a small project I'd opt for buying the mini 4-packs of small tubes . I didn't see those in this store.
Re: Clamp pads
The E6000 I used was like thin caulk
Dick Coers
I use E6000 all the time to affix wood accents to metal findings and metal project items. It reminds me of a mix of silicon caulk and rubber cement. It has a slight odor, but I am really pleased with the results!
Re: Clamp pads
the cap will not be glued on......
.....but over time the threads get filled up.
Re: Clamp pads
Re: The E6000 I used was like thin caulk
William Duffield
You probably want to be careful about how much of the solvent you inhale. Tetrachloroethylene is listed as potential carcinogen by IARC & NTP. Re-
sults of in virto Mutagenicity tests have been negative. Prudent handling
practices should be followed to minimize human exposure.
